Old 04-28-2013, 12:38 PM
Numi Numi is offline
Default 64 bit Audio Engine?
I am curious if anyone has read/heard if not only that the application runs in 64 bit but also if it processes audio in 64 bits? I am also curious if it will support 64 bit audio files now? Some applications like Reaper have had end to end 64 bit audio processing since its incarnation... And I am not arguing for or against merely just out of curiously? On the other end, the latest release of Cubase runs in 64 bit but only processes its audio in 32 bits.
So... Anyone?
Old 04-28-2013, 01:29 PM
Drew Mazurek's Avatar
Default Re: 64 bit Audio Engine?
So... Anyone?
No. Just the app has been upgraded to 64 bits.
Since PT9, naive Pro Tools, HD Native, and HDX, have all had the same 32bit floating point processing with 64bit accumulator mix buss. It's this last part that causes some confusion, understandably.
There really little to no need for 32 bit audio files (other than to keep the data path 32 bit "pure" and for certain audio processes like MASSIVE gain changes) so 64 bit audio is just silly.
www.drewmazurek.com
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Sibelius 7 Audio Engine Peter Baird macOS 0 07-30-2012 01:39 PM
HELP! PT9 Keeps Changing Audio Engine Yotonic Pro Tools 9 0 07-11-2011 08:24 PM
Did the audio engine get an upgrade with PT8? Eric Lambert Pro Tools TDM Systems (Mac) 13 01-26-2009 12:13 PM
Audio Engine twistedblues Tips & Tricks 1 03-24-2004 06:25 AM
