Mbox 2pro issues - from bad to worse
In an attempt to fix a potential hardware failure, my local music store updated my PT8 (with cs1 installed) to PT8.01. The install failed with message " The installer could not write the receipt for "plug-in updates" However now instead of having a locateable yet broken mbox, my mac no longer recognizes or locates the mbox 2pro. Hence I can't access pt.
I now get an error along the lines that "library/startupitems/digidesign Mbox 2" doesn't have the right permissions How do I fix this? |
Re: Mbox 2pro issues - from bad to worse
It sounds like you need a clean uninstall/Reinstall What is your OS? was it updated using the combo updater?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Hi flommer,
I ran a safe uninstall and then reinstalled pt8. Then I ran a repair permissions and for some reason the pt icon in the dock disapeared. The mbox power light is blinking but that's it. I'm running 10.5.6 osx. Does that help? |
as Digidesign says :
you SHOULD NOT update from cs1 to 8.0.1 first YOU SHOULD update to CS3 and then 8.0.1 |
Yeah, i know that now. Unfortunately, I guess the guy from the store didn't know it at the time either.
Any other suggestions? Next I'm going to try a clean uninstall and hopefully that will fx it. |
MBox 2Pro And Buffer Underrun | BondAudio | Pro Tools 10 | 0 | 04-09-2013 08:35 AM |
Mbox 2Pro Flashing Power Light | appleaudiond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-31-2012 05:11 PM |
Mbox 2Pro Interface | MSH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-30-2009 10:35 AM |
Mbox 2pro factory + 10.5 = disaster? | hugodrax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-16-2007 05:13 PM |
worse and worse every day. LE Mbox truly BLOWS! | tomcat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-18-2003 09:21 PM |
