Old 01-28-2009, 01:39 PM
Corto Corto is offline
Default Problem with Import Session Data in ProTools 8
Hello,
When I'm importing a track from another session with "Import session data", the chords and the markers of the other session come with the imported track, erasing all current chords and markers…
I didn't click any boxes in the import window.
Is it a known issue or do I forget something ?
Thanks for your help
Old 01-28-2009, 07:35 PM
Default Re: Problem with Import Session Data in ProTools 8
Maybe you need to UN click boxes? I haven't noticed this but I will try to pay more attention.
Old 01-29-2009, 03:27 AM
Thanks for reply
The boxes are not checked by default…
Old 02-11-2009, 05:59 AM
I know now that issue is not coming with PT HD.
Digi, is it a known issue of PT8 LE ?
Old 02-16-2009, 06:10 AM
lae777 lae777 is offline
I'm running 7.3.1 so I don't really know about PT8 but in earlier versions you can determine what parameters to import as session data. I think you need DV toolkit 2 to access all the parameters in PT LE. I think chords and markers are included (or excluded) in the toolkit. I think LE has only very basic import parameters. So not really an issue just an optional extra.
Old 02-16-2009, 07:10 AM
Thanks for the reply
Maybe you're right it's now an option but I could do it before with PT 7.4.2 without problem…
And it doesn't seem really logical to erase the session current chords and markers when you just want to import a track.
But now I've bought Eleven it's a big real problem because the only way to store the midi learn set-ups of Eleven is to make a session in wich you had made a sort of "track template" and import it with the import data function.
Old 02-16-2009, 09:38 AM
demodigi demodigi is offline
Hello,
I tried to import old 7.x, 6.x and even 5.x sessions datas (mainly MIDI but also tried aux audio and master tracks), onto new PTLE 8 session (I put some markers and chords inside) and some 7.4 sessions (opened in PTLE8).
I didn't manage to reproduce your issue. If I unchecked all the option boxes (marker, tempo and so on), nothing is overwritted in the destination session.
If checked the boxes, temp/markers etc are overwriten.
I even installed the cs1 update and no issue
Sorry.
Did you tried to checked and then uncheck the boxes like albee1952 suggested ?
Old 02-16-2009, 01:13 PM
Thanks for the time you took
I've tried what Albee 1952 suggested but I'm going to try it again…
(But with a session where I don't have to spend 30min to rewrite chords and markers )
Old 02-16-2009, 02:50 PM
Don't forget you have the very helpful "revert to saved" function (... and the auto-saved sessions) which can help you recovering a very unpredictable / not undoable nasty behavior...
Old 02-16-2009, 04:35 PM
I've tried it again… No way
I've just noticed one thing different.
With some sessions especially those made originally with PT8cs1 only the chords have been imported with the imported track not the markers.
But every time the current chords still remain erased…
Import session data problem - out_of_range cppmusic Pro Tools TDM Systems (Mac) 15 10-12-2010 10:18 AM
Import Session Data Problem...? Nathan W. Pro Tools TDM Systems (Mac) 3 08-31-2009 03:24 PM
Problem with import session data 7.1cs9? Jon_Atkinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2006 08:08 AM
Import Session Data Problem Rawbs General Discussion 1 11-10-2005 02:06 AM
Import Session Data problem scottgreiner Pro Tools TDM Systems (Mac) 1 03-30-2004 12:57 PM
