Old 07-09-2008, 02:14 PM
digifriend digifriend is offline
Default No sound for final cut express?
Hi guys...Im running final cut express on my machine. And Im not getting any audio out of it. I can see the audio levels moving on the screen so I know some sound is there but I cant figure out where to access it. I figure it has something to do with the digi audiocore manager...thats why Im asking here.
MacPro 2.8 (8X)
OS...10.5.6 (Mac) Windows 7 Ultimate
10GB Ram
640GB(Mac) 640GB(Windows 7) 1TB(Audio Drive)
Digi-002 Factory and M-box
LE 8.0.3 (Mac) 8.0.3 (PC)
Old 07-09-2008, 02:22 PM
stoneinapond stoneinapond is offline
Default Re: No sound for final cut express?
You can plug headphones into the computer's headphone output and work from there.
If you want to use Digidesign hardware you need to tell the software to look for it. There is a preference you need to set telling FCE to use the Digidesign hardware - where it is, off hand I don't know, but look around the menus and you'll find it.
Old 07-10-2008, 09:26 AM
Mikeren Mikeren is offline
If you are seeing this while capturing you can only monitor Final Cut audio from the firewire device you are capturing from--it's not a ProTools issue. On timeline playback set your view to canvas not firewire.
MR
Learn to listen. Listen to learn.
Old 07-10-2008, 09:42 AM
The Dougfather The Dougfather is offline
In FCP there is an option under i think....the edit menu, where all the firewire output devices are listed near the bottom. FCE doesn't have this menu, in which case if setting the core audio device as the default audio for the OS doesn't work then it's possible this feature may not be supported.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-10-2008, 09:50 AM
I got it. It had to do with the digi coreaudio manager...thanks for the help tho...
MacPro 2.8 (8X)
10GB Ram
Old 05-16-2009, 05:24 PM
tomhartman tomhartman is offline
Could you or someone else clarify what one has to do to get Final Cut Express to work with an MBOX II Pro?
I see posts all over the net from people who can't get audio out of FCE via Digi hardware. I'm thinking of gettin FCE 4 but have an MBOX II Pro and will avoid it if you can't get audio through my system...
Thanks
Tom
CoreAudio with Final Cut Express valkyriesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-20-2006 12:08 PM
Anyone using Final Cut Express with 002? tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-20-2005 03:11 PM
digi 002r, no sound with final cut express... ZMUSIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-12-2004 06:16 PM
Final Cut Express 2 jake_5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2004 04:36 PM
Final Cut Express & MBox? Cargoplex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-07-2004 04:07 AM
