Old 07-20-2007, 01:02 PM
ptstuck ptstuck is offline
Default Intermittent Automation Problems
I'm an occasional user of Pro Tools to mix simple commercials, generally with music and a voice.
However I have a repeated problem with automation - during playback from the beginning of an ad it seems to forget the automation volume written into the track and appears high.
This generally happens after I have reached the end of the ad i.e. I undertake repeated takes in touch mode on sections of the voice until it is peaking at 6 and not overpeaking.
However when I then go to play back from the beginning, its as if it hasn't been mixed properly, and is worst than when I started! This isn't the way I left it, but I haven't revisted this section of the ad since it was right.
Also, another issue (which I think could be related):
When opening a completed mix by another user this also played very high when I played it back and yet it was also mixed correctly! This happened when I simply opened the session and pressed play with automation in read mode so I am unsure what I'm doing wrong.
This repeatedly happens intermittently to me and I'm sure it's a simple thing but not sure what.
Can anyone advise?
Thanks in advance!
Old 07-20-2007, 06:13 PM
laki laki is offline
Default Re: Intermittent Automation Problems
Check that Automation is not "Suspended"
Check that you have volume automation enabled to be written to.
Old 07-21-2007, 08:48 AM
Danny Caccavo Danny Caccavo is offline
If you are on a Pro Toos|24 MIX system using version 6.4.1, please make sure you have updated to the latest cs version -
http://archive.digidesign.com/download/cs/641cs4/mac/
Please let us know your system configuration.
Hope this helps
Danny Caccavo
Product Manager
Digidesign
Old 07-21-2007, 08:53 AM
Hi Danny
Thanks for your reply.
I'm on Pro Tools TDM 7.3(.2 I think) on a G5 Power PC linked to a Yamaha surface controller/desk. I believe the system is up to date patches wise etc.
Laki,
I believe I have the volume automation set and haven't changed the 'Suspended' settings tho I will double check this on Monday. It'd an odd issue as it happens intermittently and our Dubbing Mixer doesn't have this problem and we are both failing to see what I am doing wrong!
Thanks everyone
Automation Problems in PT9 Trumpet_Time Pro Tools 9 1 09-13-2011 12:07 PM
Automation playback intermittent rhumphries Post - Surround - Video 6 06-21-2011 12:02 PM
Intermittent Pan Automation!! ARGH!!! timsound2006 Post - Surround - Video 17 12-15-2007 03:49 AM
Automation Problems Jeffrey Talbot Pro Tools TDM Systems (Mac) 0 05-24-2001 01:32 PM
Automation problems ? Melodymaker Pro Tools TDM Systems (Win) 1 10-21-1999 10:35 AM
