Re: Loop length & meter setting in Strike\'s Style
yea i end some guitar solos with a 2/4 measure, and strike doesn't keep sync with it, i solved it by taking the synce to bar, beat option and just put it on off. when i make midid notes i just make sure they are quantized and it works for me.
How about making Strike react the same way to key commands as the edit window does, when editing styles?
And yes, add some more sounds/kits Keep up the good work Digi
Did you talk to your talkbox today? |
strange ground loop-style sound, only in PT?! | David Watts | macOS | 4 | 01-08-2014 07:49 AM |
Setting of 'Edit Window Default Length' | critictalk | Tips & Tricks | 1 | 07-30-2013 10:39 PM |
Strike Edit Window Loop Length Setting Question | JCWarrior | Virtual Instruments | 3 | 11-03-2007 01:31 PM |
Meter length in Strike | lwilliam | Virtual Instruments | 1 | 09-01-2007 06:51 PM |
