Microphone Suggestions for Film?
I'm budgeting for a film project, which will be recorded and mixed in PT|HD 5.1. I'm putting together the system now. I've got four types of microphones I need to get, and perhaps multiple mics for each role. Here they are:
ADR - male and female actors Foley - on a foley stage, stereo needed Location recording - various sources + atmospheres On-set Dialog Boom I have some good ideas for each of these, but a little extra push would help! Also, I'd like to get a nice multi-channel preamp to feed the system in the studio for foley and ADR. Perhaps something transparent, like a True Systems Precision 8? Everybody pitch in! Thanks - |
Re: Microphone Suggestions for Film?
Here's my two cents:
On-set Dialog Boom: Sennheiser MKH60 ADR: Sennheiser MKH60 Foley: Sennheiser MKH60, Neumann TLM-103 or Shure KSM-44 Location recording: Sennheiser MKH60, and MKH30 Don't forget a pistol grip, zeppelin and a woolie for the MKH60 & 30 (I like the Sennheiser stuff better than the Rycote). For stereo can clamp the MKH30 to the MKH60 for M/S. I haven't done this for Foley but they both fit inside the zeppelin together and work great for stereo ambiences & such...
Yesterday, I cudn't evun spell injunear. Now I are one! |
Thanks Thomas for the quick reply -
I see you like for the Sennheiser MKH60, which seems to be a very popular piece of equipment for this kind of work. As is the MKH416, which is a bit cheaper. Do you have any experience with this one? I''d love to hear your thoughts on the general tonal difference of the two. I also see that you suggest using it in the ADR as well, which is a very good idea. Very often a large diaphragm condenser is used in the ADR, to capture the "best sound", but truth be told, you want the dialog tone to match what is already being kept from the on-set dialog. Unless of course you're re-recording all the dialog, in which case it might make more sense. Good call, and I will keep that in consideration when I start purchasing equipment. Now excuse my ignorance, but do i need a woolie if I have a zeppelin? |
416 is the standard benchmark @ 25mV/Pa
60 is a nice option @ 40mV/Pa plus HPF and 10dB pad
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I have an MKH60 and it is really nice although it does seem a bit short when using it outside. I also seem to get a nice hiss that's pretty high frequency whenever I use it. I'm not sure if that is normal or not or am I expecting too much from a shotgun mic? For example my U87 is rediculously quieter than the MKH60. Is this to be expected? I use a Millennia preamp or a Focusrite Green Range preamp when I use it. The hiss might also be caused by the poor preamps in the video camera that I sometimes hook it up to.
Craig, sorry for the question, but I have some catching up to do - what exactly are you referring to?
And even if you're going to ADR all the dialog for all the actors, I still like to use a "production" type of mic and use a mic placement that emulates what was done in production. VO and narration is another story... [/QUOTE] Quote:
I hate running sound to the camera!!! And not just because of the crummy preamps and/or A-D convertors. If they insist, I'll send them a stereo feed from the mixer but record to my own recorder.
The industry standard for interior dialog reocrding from an overhead boom is either the Schoeps MK41, Senn. MKH 60 or the Neumann KMR81. There are many other good mics available to do this work, but these are the ones against which the others are measured. Outdoors shotgun types are preferred, usually Neumann KMR82, Senn. MKH 70 and Sanken CS3. For the latter you will need a serious Rycote or DPA style zepplin windscreen, for the former, at least a foam windscreen. The choice of fishpole is a personal one--in the US most use vDB or KTek. There are many other necessities for getting set up to do location sound, not the least of which is a mixer, some way of communicating with your boom op and a way of sending a monitor feed to the director, script supervisor and a host of other people who want to hear the dialog as it is recorded. For more info on all this, ask on RAMPS (Google Group).
Philip Perkins CAS |
mV/Pa: mV per Pascal
1 Pascal = to 94 dB SPL so at any given SPL level the MKH 60 will output more voltage than the MKH 416 useful if you are micing mumblers and bunny farts
Microphone suggestions? | 1redvettefor2 | Pro Tools 10 | 28 | 12-30-2012 03:39 PM |
Suggestions for Film Mix Effect | One Track Music | Post - Surround - Video | 12 | 05-19-2003 09:33 PM |
Choir Microphone suggestions | jiagap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-16-2002 06:51 AM |
microphone suggestions.... | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 47 | 02-06-2002 06:36 PM |
microphone suggestions? | Ssaidvox1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-24-2001 05:23 PM |
