Old 11-12-2004, 06:56 AM
ZMUSIC ZMUSIC is offline
Default digi 002r, no sound with final cut express...
hello,
I'm wondering if anyone here has had any luck monitoring the audio in final cut express through their digi 002r hardware?
I'm using core audio driver 6.5.1 and all my other programs route audio through it perfectly (including imovie).
I've found no known issues listed in the core driver pdf.
any help would be appreciated!
thanks,
-d
G5 dual 2 gHz
2.5 GB ram
Digi 002r
Old 11-12-2004, 11:21 AM
Mikeren Mikeren is offline
Default Re: digi 002r, no sound with final cut express...
I've got FCE1, the audio doesn't work with core audio as far as I can tell (not an issue, just the way it is). I've connected the Mac's audio out to the Alt. Source inputs on the 002. It allows me to monitor exclusively through the 002-- just push the ALT SRC to Monitor button for anything that doesn't work with Core Audio.
MR
Learn to listen. Listen to learn.
Old 11-12-2004, 06:16 PM
hey MR,
That's a great solution!
thanks a lot for your post!!
-dz
No sound for final cut express? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-16-2009 05:24 PM
Final Cut Express and Digi Hardware? tomhartman Pro Tools TDM Systems (Mac) 0 01-15-2007 09:37 PM
CoreAudio with Final Cut Express valkyriesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-20-2006 12:08 PM
Anyone using Final Cut Express with 002? tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-20-2005 03:11 PM
Final Cut Express 2 jake_5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2004 04:36 PM
