  #21
Old 05-09-2023, 03:02 PM
nst7 nst7 is offline
Default Re: Carbon Expanded - ADAT
Agreed with the last post. For expanding the Carbon, you should look at getting the Carbon Pre. Up to two of these can be used with your main Carbon, giving you 24 i/o, plus the adats on the main unit.
  #22
Old 05-09-2023, 08:54 PM
patmaki patmaki is offline
Thanks all for your inputs, very helpful. Was able to cancel to order for the HD I/O. Not crazy about having to add the two carbon pres to the carbon to get up to 24 channels of I/O, so will have to phase in the carbon pres over time. Anyway will get the carbon in and put it to work and see if I can't live without it. Jury's out.
  #23
Old 05-10-2023, 02:04 AM
The total amount of DSP processing power is the same regardless of whether you buy
a) Carbon + Pre + Pre
b) Carbon + MOTU 16A
In other words, the HDX chips are only in the Carbon.
The difference in the above setups are:
a) all channels can work at up to 192KHz. (Although you probably won't have enough DSP for tracking 24 channels at 192 with plugs).
b) you are limited to 24 channels at 44.1/48. Or 16 channels at 96KHz
a) PT can control the preamp levels (+phantom etc) of all channels
b) You will need to control the MOTU separately
a) alignment of converter delay is catered for
b) aligmnent of converter delay needs to be calculated. Good luck. Usually fine if you don't use a stereo pair split across devices.
a) pretty matching boxes
b) ugly MOTU box. Yuk.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #24
Old 05-10-2023, 04:42 AM
digiot digiot is online now
Dominic
There are other options then the MOTU. The Ferrofish is a popular 16x16 option but personally I use an old Apogee AD16X to connect my 16 outboard mic pre’s to my Carbon over ADAT. I hardly ever use the Carbon Mic Pre’s other then for the 2 DI’s for bass or guitar. And I always run at 48k. I recently had to replace the AD16X and found one on Reverb for $500! I paid over $3k for my first one 20 years ago.
  #25
Old 05-10-2023, 04:58 AM
Yes, but the other options (including the one you mention) have similar limitations. The Carbon only has 2 ADAT in ports, so you can never get 16 channels in over ADAT at more than 48KHz. You won't be able to control the preamps from ProTools. MOTU was just an example. Other boxes may look more attractive.
Dominic
  #26
Old 05-10-2023, 05:20 AM
Dominic
I agree completely, I was just giving options to the MOTU which is ugly as hell!
Also the person that we replied to never mentioned he needed 24 IO’s at 96k and in his last post he was considering just the Carbon with its 8x8 IO.
As for remote Mic pre’s, I never saw the use of it unless if used in a remote situation(pre’s on stage). I much prefer to touch the knobs on my mic pre’s
  #27
Old 05-10-2023, 12:35 PM
K Roche's Avatar
K Roche K Roche is offline
Well besides the fact that ugly is totally subjective .
One would think the quality of the audio and functionality would be paramount over looks --but hey to each their own
As for the usefulness of the mic remote feature it's kinda like a TV remote, not necessary, but pretty damn handy
I personally like to have the ability to control some features right there at the top of all the audio tracks channel strips with out having to look away from the session.
#1 link or unlink pairs of tracks
#2 turn phantom power on and off
#3 set or change input gain levels
#4 select mic or line level
#5 reverse polarity
Now to be sure you do not have the tactile thing but then ya don't have that in a DAW mixer anyway
and all that is totally subjective also AND does not actually detract from, or diminish, the usefulness --jusss sayin'
System :
Enjoy the Journey
.... Kev...
  #28
Old 05-11-2023, 07:50 PM
Correct, my goal is to have 24 I/o at 96kHz. Would be great if Avid would put out an equivalent to UA's X16, but for now will need to add two carbon pres. Anyway, got the Carbon up and running and tracked a drum session today. Liking it very much so far. Will probably put my UA X8 and X6 up for sale to help fund the endeavor. Thanks again, for the solid inputs here.
  #29
Old 05-17-2023, 06:33 AM
K Roche's Avatar
My Guess is and it is only speculation (and could be wrong) is that Avid will likely not offer any additional AVB expansion units for the Carbon
Remember it is targeted at the user who does not need more than (now with Pre option) more than 24 inputs
What they will likely do is revamp their full blown HDX offerings for users with larger input needs.
The good news is Carbons mic pre's and conversion is top notch and the seamless single window integration with PT is a breeze to work with and my guess is you find the in the track Pre control feature will be one of those things you never thought about and didn't miss UNTIL you actually have it (kinda like a microwave oven )
System :
Enjoy the Journey
.... Kev...
  #30
Old 10-10-2023, 05:15 PM
noah330 noah330 is offline
I'm using my Carbon with an older SSL AlphaLink that was part of my HDN system and an Omni.
It's kind of a shame because I have eight SSL channels that are pretty useless because of SSL's routing. I wish it could mirror the A or B ADAT-ins because then I could use it with one of those Behringer monitoring systems or something.
At any rate, the SSL converters sound good and the unit can be found for cheap these days.
I'm using the line in/out on Carbon to a patch bay and it handles my outboard fairly well:
2 LA-2A
1 1176
1 DBX 160A
1 Lexicon
I'm also using those lines for some external pres when tracking.
I have the 16 ADAT outs going to the SSL to send 16 analog signals to an API The Box, then I return through the program sum to Carbon's line-ins.
It sounds a lot more complicated than it is.
If Carbon would have had 24 ADAT it would be perfect, but compared to Apollo, and at the no-software price, it's hard to beat IMHO!
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Pro tools Carbon and ADAT Rob Hannon Pro Tools | Carbon 10 02-09-2023 12:18 PM
Can I use Carbon ADAT OUT with 8 Preamps Simultaneously langa101 Pro Tools | Carbon 4 01-22-2023 02:17 PM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
Adat detection Problems With Carbon Mike_sound Pro Tools | Carbon 14 10-23-2021 06:28 PM
16 channels of ADAT i/o from an un-expanded 192 GKF Pro Tools TDM Systems (Mac) 4 03-22-2007 04:09 AM
