Old 01-06-2019, 04:32 AM
edwinstar's Avatar
edwinstar edwinstar is offline
Default HEAT messes up LLM Delay Compensation
Hi everybody,
I decided to start a new thread, because i think this is an interesting issue, probably even a bug:
What's the issue? Record enabled Track plays ahead of rest of Session before punch in and sounds super-not-groovy!
Normally when I have a Session with let's say 2500 Samples total system delay, use Low Latency Monitoring (LLM) and then decide I want to punch in on an existing Audio Track, looking at the Delay Compensation Numbers I can observe that even when record enable is pressed, existing Audio playing before i punch in will be compensated for those 2500 Samples and sounds right on the beat.
BUT: when I have HEAT activated, the existing Audio on the record enabled track is only shifted 430 Samples instead of 2500 and as mentioned above, sounds super-not-groovy!
Only Solution: Turn off HEAT Globally!
Anyone else experiences this? Is it a bug? Should I report?
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
Bus send messes up Delay Compensation Peterjk Pro Tools HDX & HD Native Systems (Mac) 1 05-31-2013 01:07 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
HEAT and delay compensation WildHoney Pro Tools TDM Systems (Mac) 16 08-24-2010 02:40 PM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
