Old 06-28-2018, 12:48 AM
Maxidingue Maxidingue is offline
Default Audio Engine probleme
Hi all Protools Users,
I am running Protools 2018-4 on my iMac core i5 3.3 MHz with 24 Mo RAM
My OS is Mac OSX High Sierra
My "sound card" is a Behringer X32 Rack
I also own an S3 station
Until now everything was OK but yesterday when i tried to load the last projet i made, i have a strange message stating that "Protools was unable to find the sample rate frequency on the mentionned value" (or something like that. I am french and tried to translate.
Reinstall Protools but always the same message
My Behringer X32 work fine with Ableton Live and all my gear hook to it
Any help
Thans a lot
MaxIdingue
enclosed the french message
File Type: jpg Capture d’écran 2018-06-28 à 09.35.45.jpg (25.6 KB, 0 views)
Old 06-28-2018, 09:34 AM
The Weed's Avatar
The Weed The Weed is online now
Default Re: Audio Engine probleme
It might be a sample mismatch between Pro Tools and the X32. What is the sample rate of the session and what sample rate is the X32 set to?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-28-2018, 01:23 PM
Emi's Avatar
Emi Emi is offline
I had a similar issue using Protools with the x32. It was because the board was in sync with another X32 (it was switched off) that was giving word clock to the one I was hooked. So check the set-up menu of the X32, see if switching it to internal sync will work.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 06-29-2018, 12:33 AM
Thanks a lot Emi. My X32 synchro is OK set to internal and sample rate to 48 kHz.
Anyway, i read somewhere that the audio engine has changed between Protools 11 and 12 from DAE (Digital Audio Engine) to AAE (???) or something like that. So i reinstall PT 11 than upgrade to PT 12.8 and............
It work now
I wonder if i can upgrade to PT 2018 now ???
SIncerely
Maxidingue
Old 06-29-2018, 02:39 AM
PhiBee's Avatar
PhiBee PhiBee is offline
Why not ? You can have both version: 12.8 and 2018.4. Just rename the old one 12.8 to v12.8 for example BEFORE installing the last version. And so, you could switch between both.
I'm always doing that when a new version appears.
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
Old 06-29-2018, 02:49 AM
Southsidemusic's Avatar
Nope. The Audio Engine was changed from PT10 and PT11. Not PT12. In PT10 it was DigiDesign Audio Engine (DAE) and now Avid Audio Engine (AAE) and that was introduced along with 64 bit structure in PT11.
The DAE was only 32 bit and was used from 10.3.10 and below.
The AAE is the current version and was introduced from 11.0.0 and is a complete rebuild from the gound up (Avids words) and is the architecture is now 64bit which is the same as in 12 and 2018.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-29-2018, 05:13 AM
Thanks Christopher,
Anyway, i re install PT 11 than 12.8 and now 2018-4 and it work fine
Regards
Maxidingue
Audio engine digiplex Pro Tools 2018 7 04-09-2018 02:08 PM
64 bit Audio Engine? Numi Pro Tools 11 1 04-28-2013 01:29 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
PT probleme Shevanelflip Pro Tools 10 3 03-07-2012 07:59 AM
Audio Engine twistedblues Tips & Tricks 1 03-24-2004 06:25 AM
