#91
Re: hdx aaxdsp is dying
So.. how does it perform at low buffer playing VI's live? Please excuse my frustration.. you have no idea how difficult it is to find out this information.. I have been trying since last September
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#92
the same way a native rig does…less latency when playing keys and stuff. I must set my system at 128 to be comfortable to use vim's.
ej |
#93
I am really worried about performance specifically at 64 buffer at 44K or 128 buffer at 96K those are unusable for me with core audio Pro Tools, cpu spikes galore - but i can use them in cubase and Logic.. I was hoping the HDX might be better since it talks directly to pro tools rather than core audio. Right now the minimum i can use is 128 at 44k and 256 at 96k
#94
TNM - Do you know anyone with HDx in your area? Getting your hands on it would be a good way to feel it out. In the off chance you find yourself in New York city you are welcome to check it out with me. Tracking anything with HDx is great because of this as I often record MIDI parts after many tracks have been laid down. C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#95
mac pro 3.06 12 core 64 gigs of ram pt hdx 12.4 mac os 10.8.5 magma eb7 chassis that being said their may be some issues with my rig that i am looking into as I am not getting the expected performance out of my system that i would like (uneven cpu usage and spikes, drop outs at lower buffer settings and jumpy mouse, aae 9171 errors sometimes cause by scrolling or gui tweaks in plugins). i did a test earlier today and on the same session there was little difference between cpu usage running hd native and hdx (yes i can run either playback engine). When tracking vocals today there was no noticeable latency issues at a 512 buffer. when using keyscape there was a noticeable lag. once i got down to 128 buffer it was for sure playable. at 64 buffer it was fantastic but i was getting spikes and dropouts…which i should not be getting on my system. issue could be mac hardware related, os related or Pro tools 12.4 related…not sure yet. what was really cool though is that i was able to record with this chain keyscape brainworx n console dsp uad 1176 rev A native revibe dsp compressor bank native however when running hd native i could record through the same chain. once if figure everything out I should be able to do this at a 128 or 64 buffer and just leave it without worry. that is the goal for me. once i get the kinks worked out then it will be awesome. Final note. when discussing with some of my composer friends on hdx and trash can macs, they prefer doing all of their midi through vep instead of protools. I don't particularly enjoy sequencing in pro tools as i find it a bit cumbersome but do like the ability to add parts if needed when editing or mixing. |
#96
no the spikes and dropouts at 64 is pro tools related..
so sadly it's the same. I don't know anyway of testing a hdx system with anyone nearby, i only know those with HDN and 64 was not very usable for VI's and lots of armed tracks with effects. This is why i might as well just stick witch my apollo at 128 buffer and monitor through console rather than spending all that money... Or just complete the migration to cubase. thanks for your help
#97
I will upgrade CPU by mid next week. Did an autotune test today to see how it works recording thru auto tune. I've always had tdm versions so leaving it at 512 buffer has always been fine. Autotune native on hdx has delay of over 1000 samples....even the live version. Buffer has to be at 256 or lower in order for AT to be useable. 128 was better. 64 was fantastic but I can't sustain that.
Will see what happens after CPU upgrade. |
#98
Autotune live has 0 samples.. so if you set the buffer at 128, there is no way it is 1000 samples total even through the HDX double buffer. The moderator at gearslutz uses autotune live in HDX at 164 samples total.
#99
#100
Dying here people.....Anyone....Anyone ??? | RHDRAMA | Pro Tools SE and Essential (Mac) | 12 | 02-22-2011 03:07 AM |
Protools LE: A dying Daw? | agami_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-13-2010 02:08 AM |
Dying M Box? | deafmute | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-01-2008 03:32 PM |
Is TDM Dying? | EarHole | Post - Surround - Video | 32 | 09-07-2006 09:11 AM |
I'm dying here!!!!!!!! | FatBelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-25-2003 01:25 AM |
