Not enough Firewire ports
Ok here is a connectivity question for a 2011 13" MBP. I'm looking at purchasing one of these to use with my Digi 003. Heres the problem: The 13" MBP only has one Firewire 800 port. How do I connect a firewire audio drive and Digi003 with only one port?
Any suggestions? Anyone already running this setup? - Chris |
Re: Not enough Firewire ports
“What fresh hell is this?” - Dorothy S. Parker |
FW drive FIRST into MBP, then Digi003 into the 2nd FW port on the HD.
This is the recommended configuration. But if you have problems, it's okay to reverse the order of the components. And don't forget you will need a Firewire 400-to-800 adapter cable somewhere in the setup...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
1) I thought daisy chaining the 003 to the firewire drive affected maximum track count. This is what digidesign's documentation states. Has something changed?
2) I also saw a note about chaining a firewire drive to the 003 and then to the mac. I believe it said something about the 003 not supporting data pass, which i believes means if the 003 is off, the hard drive won't work? Is this correct? anyone done either of these options had any problems? are there other options besides daisy chaining? Thanks for the advice - Chris |
The 003 can do a maximum of 18 tracks at 24-bit/48kHz. You will not have a problem if you use a compatible drive.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
iMac/MBP FW800 > G-Drive > FW800-to-400 cable > MBox Pro Will this work?
PT 2021.12.0 w/Focusrite 2i2 iMac i7 3.8GHz / 72GB RAM / Mac OS X 12.1 https://linktr.ee/sergius128 |
It should, but if you have problems, try reversing the order: mbox Pro, then G-Drive.
MacBook Pro > Glyph HDD > 003
No problems here but the occasional "lost communication with device" error. That'll end when my LaCie Thunderbolt eSATA hub arrives :)
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
I use a powered firewire hub with 0 issues. Just remember to eject your drives before shutting down the computer. I also turn the drives on about 1 second before turning on the computer. They are in a separate power distribution unit.
Macbook Pro, Glyph Drive, Some noname drive (for backup), (2) Profire 2626's. I use the firewire 400 ports on all of them. |
Digi 002 Firewire 400speed not accepted by new Mac Pro Firewire 800speed ports | AncientMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-15-2010 09:31 PM |
firewire ports???!!!! | icarus73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-01-2007 08:28 AM |
FireWire Ports on MBP | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-30-2007 08:35 PM |
002 firewire ports | xtina910 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-07-2007 06:04 PM |
firewire ports ? | quaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-03-2003 12:07 AM |
