Re: You guys helped once, please help again: swirling noise
I'm no expert when it comes to the Eleven Rack but I had a similar issue a few years ago with another modeling guitar amp. I also heard a swirling sound that seemed to ride on top of the guitar sound. It was there anytime a signal was present but not there when the signal was muted. It acted almost as if a gate shut it off when there was no signal but as soon as a signal came through, the swirling was there again. Here is what work for me in that case. I was using a standard power strip. I replace it with a Furman power conditioner and it got better but was not completely gone. I replaced that with a Monster power conditioner and that worked. The swirling was gone as far as I could hear. My guess is that the power conditions in my house had some noise from some appliance or other device that was injecting this noise into the line. The power conditioner was able to clean that up. I don't know if this will work in your case but it is worth a try.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
FWIW this "issue" has been mentioned before and discussed quiet thoroughly, even Chimp and Chris chimed in. The result was, the issue could not be replicated by Avid.
You can check out that thread here: http://duc.avid.com/showthread.php?t=297502 It's also important to note that some amps, the real amps, have ghost notes, and the Eleven Rack models stay true to the actual amp(s). One person that said they could hear an exaggerated swirling installed Firmware 1.0.3 over 2.0, then re-installed 2.0 over 1.0.3 and said that the swirling was then less. However, if you read the tests that Chris did, samples from 1.0.3 and 2.0 both nulled, so they are the same. Its important for me to mention that at that time, no 11R's were shipping with the ERXP pre-installed. The ERXP was purchases for $99. So if you have an 11R that had the ERXP PRE-Installed, and you install 1.0.3 over it, YOU WILL LOSE ACCESS TO ALL AMPS,EFFECTS,CABS,MICs ect... that were added by the ERXP. If your 11R came PRE-INSTALLED with 2.0.1, and you install an older firmware over it, and then want to go back to 2.0.1, you will have to purchase the ERXP, or call Avid and see if they will show mercy on you and provide you with the needed SN and ID codes. Quote:
Also please save the rig you use for the sample to your computer, and upload that as well so we can all try it and see if we can replicate it on our systems. There are several free sites where you can upload the sample(s) to, like, SoundCloud.com, Box.net, Mediafire, Dropbox, ect.... Thanks
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
It will be so much easier for everyone to help you if you post a sample so we can listen to it on our systems and try out the rig setting on our systems, instead of trying to interpret what you mean by 'swirl' - if it is completely unusable as you say, then we should all be able to hear it pretty readily, and maybe be able to offer some solution.
#16
I will when I get a chance.
#17
Have you had a chance to record a short 20 -30 sec track yet so we can hear the swirl you speak of? it doesnt have to be fancy, just straight fifths will be fine.
#18
Ok I just did. How do I post a .mp3 here? Also, saved the eleven rack settings but also no way to post them here either. I'll email them if someone would like me to.
#19
#20
Here you are. It is single notes. You should be able to hear the ghost fizz and slight swirl. 3 settings were used with 2 amps mods. the RB-01b red and Plexiglass.
The guitar is a 50th Anniversary 1960 custom shop Les Paul ver.2 http://soundcloud.com/jon9/swirltest |
How do you guys use the noise gate? | jhumber | Eleven Rack | 5 | 03-09-2011 01:10 PM |
Thank you to all who have helped today.... | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-15-2004 02:02 PM |
HELPED NEEDED PLEASE | CHRS | Tips & Tricks | 3 | 10-30-2003 07:37 PM |
How can you penalize who helped you grow? | MAXIMUSIC | Pro Tools TDM Systems (Mac) | 33 | 09-17-2003 07:05 AM |
To all who have helped: thanks & hallelujah!! | athlone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-11-2002 09:48 AM |
