Old 06-21-2006, 11:30 AM
Mindcrime Mindcrime is offline
Default Having a minor issue with XP and RTAS
Does Windows XP SP2 support RTAS on PT LE 6.9? This may sound silly but I'm used to using Pro Tools LE 6.9 on a PowerMac G5, and during playback I was able to go to the mixing console and insert RTAS plug-in's on the fly.. that way I can get an idea if an audio track needed any sort of effects and how much to apply. It seems that in XP I only have Audio Suite, and that wont let me hear the track with the plug-in I choose during playback (it's only, here is the track.. how much adjustment do you need and you can only preview that specific audio track). On XP with PT LE 6.9, if I go to the mixing console and click on the inserts all I get is a list of I/O puts and busses (i.e. Line Mic 1 Line Mic 2) but no plug-in option like my Mac did..
Is this the way it is or do I need to make an adjustment to get XP to work with RTAS. Or is it only audio suite with XP?
I appreciate any and all help that you guys can give..
thanks in advance
-Chris
Old 06-21-2006, 11:52 AM
spkguitar's Avatar
Default Re: Having a minor issue with XP and RTAS
The MAC and XP versions of Pro Tools function the same. If there are no plugins listed on your inserts, there is something wrong with your software installation.
Old 06-21-2006, 12:22 PM
Hey, thanks for the fast reply...
PT LE installed just fine.. everything else works good. I just have no RTAS. Do you think there is a setting I need to adjust to get it to function?
P.S, Im from NoVa too..
Old 06-21-2006, 12:32 PM
spkguitar's Avatar
No, if they show in the audiosuite menu, they should show in the insert/RTAS menu. I would try a re-install just to make sure. Also, did you install everything to the default locations?
I won't be from NOVA in exactly 48 hours... major move.
issue recording with RTAS supertonsil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-12-2011 06:37 AM
Rtas processing issue josh18t Pro Tools M-Powered (Mac) 0 08-01-2010 09:43 AM
Minor Track List Issue dmacintyre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2009 06:25 AM
Minor Issue, Probably a simple fix Eless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-31-2005 05:38 PM
VST 2 RTAS Issue. Gkyaun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-2004 04:39 PM
