ERROR -9093
Anyone have issues with a pci-ata 133 card & system crashes, problems bouncing to disk etc. or do I just have a bad drive. Using a Western Digital 7200 rpm 120 gig partitioned into 2 60 gig drives. running on a 733 G4
Re: ERROR -9093
I've seen quite a few problems with large drives. It seems that these may not be as reliable as under-80gig-drives. This is a feeling due to what I see with my customers and not a scientific, proofed analysis.
I wouldn't go above 80gigs. Did you try a benchmark test? |
Re: ERROR -9093
hmmm? did a benchmark, came back at the top of his class..maybe partition to 3 40 gig drives/ or just stick with an 80. the 80 on the ata bus screams.
thanks |
Re: ERROR -9093
I had this problem for several months. I, too, have a 120 gig drive and started having problems with bouncing to disk a little while after setting up my system. I did searches on it and many people had this problem accompanied by very long threads and I never found out why. I also noticed the bounce handler could not keep up only with certain sessions. I figured out why about two weeks ago.
Now, I'm not sure if this is obvious or not, but on the sessions where I could not bounce to disk I had Absynth(Native Instruments Software Synth) inserted on an aux track. Once I took it out everything worked fine(as well as overall increase in Pro Tools performance). This may only be an issue with Absynth as it's the only softsynth I can vouch for, but maybe not. Sooo, if you don't have a softsynth inserted on an aux track in these sessions you're having problems with, then nevermind, but this problem may be happening to others so I hope some become aware. I'm glad I am. Hope it helps you. Mike |
Re: ERROR -9093
Hello,
Try moving the drive to the built-in ATA bus on the Mac. We don't test or support ATA cards and its possible that may be your problem. Mike |
Error 9093- Need some help... | cclarkaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-21-2008 06:02 PM |
DAE ERROR 9093 | Babu1210 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2007 01:16 PM |
error 9093 | FernandoJMercado | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-03-2003 07:03 PM |
1 Cure for error 6085 and error 9093!!!!!!!!! | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2002 07:30 AM |
-9093 error, please!!!! | EDurney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-18-2002 12:28 AM |
