-9093 Error with i7
I'm having the keep having the -9093 error every time I press play.
Here's my specs: Processor: Intel Core i7 Processor i7-950 3.06GHz 8MB LGA1366 Motherboard: GIGABYTE GA-EX58-UD4P Ram: Mushkin DDR3-1333 6GB (3x2GB) CL6 (2) Western Digital black 1TB SATA2 7200rpm 32MB Drive: Sony Optiarc AD-7241S-0B 24X Video Card: Asus ATI Radeon HD4670 512MB OS: Win XP EDIT: I just set buffer to 1, and set my sessions to 2nd drive. I think everything is fine now. Last edited by Mr.R23; 10-13-2009 at 06:47 PM. Reason: Added extra info |
Re: -9093 Error with i7
I thought I solved my issue, however after playing with it a bit more, seems the error keeps popping up randomly. Can anyone help me out.
It might help to post a Sandra report on your system.
What version of PT are you running? What interface are you using?
Here's my Sandra Report. I'm currently running Protools 8 and the MBox 2 interface.
Anyone can help? It's gonna drive me almost crazy lol
1) make sure your ram is in triple channel mode 2) put ram settings in manual mode 3) set each channel to proper timings (your current timings look kinda loose for ram speed. check ram specs)
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Do you know would I go about changing my timings and setting it in tripple channel (would I have go into the BIOS?)? According to the ram, it says its timing is Timing 6-6-6-18
Ok.I went into the BIOS, and changed the Extreme Memory Profiler X.M.P. to enabled.
Was that the right way to change the RAM timing? There were so many functions, I didn't know which one to choose. |
that's one way to do it. personally i would want to set mine manually and not rely on XMP profile. not tryin' to be difficult or anythin' of the sort but your manual has all that stuff covered. also i think i covered it within the last 20 pages or so in the i7 thread. as far as bein' in triple channel mode, your mobo has color-coded dimm slots that direct you
I just have 2 more questions, after I do the suggested adjustments, is there a program or way to tell if I am in triple channel memory, and a program/way to check my the new adjusted ram timings?
Error 9093- Need some help... | cclarkaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-21-2008 06:02 PM |
ERROR -9093 | Soth41 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-11-2003 11:19 AM |
error 9093 | FernandoJMercado | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-03-2003 07:03 PM |
1 Cure for error 6085 and error 9093!!!!!!!!! | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2002 07:30 AM |
-9093 error, please!!!! | EDurney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-18-2002 12:28 AM |
