Old 03-05-2019, 02:39 PM
MixerPro MixerPro is offline
Default Re: ProTools with wireless headphones + Bluetooth codecs
I had the same problem.
My old headphones (AKG 50 which I recieved as a gift when I purchased Samsung Galaxy Note 8) have been not synchorized with Pro Tools.
So, after reading a review about Samson SR850 on https://whoishuman.io/cheap-studio-headphones/, I have decided to buy especially because of the quality of sound and its cheap price.
Guess what, pairing problems have not been resolved. So, I discover that you are using a really old version of Bluetooth (my macbook pro 2012).
Old 03-05-2019, 02:49 PM
hillofbeans hillofbeans is offline
OK, so Loopback works perfectly for this.... but it's costs too much $120 to justify the expense.
Soundflower - it might work, but I tinkered for a long while with no success.
It's a real PITA that ProTools doesn't want to play ball, when all my other apps work fine with these headphones.
MacBook Pro 2015 OS X 10.13.3
ProTools 12.7.1
Old 03-05-2019, 03:29 PM
kelsey's Avatar
kelsey kelsey is offline
Dante VIA will do this too. I believe it cost less, but can't remember how much. Made by the same folks responsible for Dante audio networking.
https://www.audinate.com/products/software/dante-via
The open source software you are looking for is called Jack, and it works on Mac too.
http://www.jackaudio.org
https://wanderingear.net
Old 03-12-2019, 11:03 AM
AE AE is offline
i had the same problem using my AKG N60NC Bluetooth phones. this worked:
install the free Ladiocast app, available at the App Store.
install Soundflower, also free.
switch the Pro Tools Playback engine to Soundflower (2ch).
route Soundflower (2ch) to a Ladiocast input and make sure that input is assigned to Main.
route the Ladiocast Main Output to your headphone driver.
play your Pro Tools session. viola!
Old 04-04-2019, 06:13 PM
OK, so I figured it out...
After entertaining many, many options, the solution was amazingly (and dumb on my part) simple.
All I did was to use the PT Aggregate I/O and remove EVERYTHING, except the output of my Bluetooth headphones.
PT only freaks out when the headphones' mic is selected.
Thanks for everyone's input on this. Really appreciate the support
ProTools 12.7.1
Old 06-26-2019, 05:41 AM
Fritz Fritz is offline
@ Sardi.
Been trying to use Loopback so that I can use BT in-ears at the same time as my Apollo 8 I/O to speakers.
So far, every method I've tried kills my HW insert or causes nasty distortion in the IEs.
I think I must be doing something wrong in the config.
have you any input?
PT10 under Mavericks.
"Do not fear mistakes. There are none."
Miles Davis
Old 01-15-2020, 09:54 AM
improvpwnd improvpwnd is offline
This is the correct answer.
Old 02-22-2020, 06:51 PM
MBseva MBseva is offline
I was inspired by this thread to try the Loopback trial download, and it IS brilliant. And spendy. So I wrote to Rogue Amoeba to ask whether they had some other clever product for just getting the sound to my AirPods. (Or whether they'd consider a discount for a sincere inquiry...heh).
They suggested their Sound Source app, which is much more affordable and quite clever in its own right.
However, it does not do the trick. Does not show up as a Playback Engine (so that is Loopback's secret... maybe the code-formerly-known-as-Soundflower in there?) and does not talk to PT Aggregate IO.
I'm all ears if somebody knows how SoundSource could work!
Why AirPods? Because I'll be care sitting with my 93-year old mom and would like to get some editing done, while monitoring her. Transparency mode is awesome!
I have dropped another note to the very helpful RA tech support, and I will update after hearing back from them with a solution - $29 bucks if so - or kaffkaff, buying Loopback. Sigh.
2021 MacBook Pro
M1 Max
Mac OS Ventura 13.6
internal 4T SSD
Pro Tools 2023.9
MBox Studio
Old 02-23-2020, 01:09 PM
Lynn Gräber Lynn Gräber is offline
Anyone looking for a great free loop back utility, look for Blackhole.
Old 02-23-2020, 06:55 PM
Confirmed, Sound Source will not do the trick, since Pro Tools does not have a default output.
I read about Black Hole and a couple of other open source loopback utilities, but did not have the know-how. Also, commenters said some were buggy or not ready for Catalina.
2021 MacBook Pro
M1 Max
Mac OS Ventura 13.6
internal 4T SSD
Pro Tools 2023.9
MBox Studio
In 2014 Why do Bluetooth and Wireless need to be disabled? propower macOS 4 01-18-2014 05:55 PM
Wireless Bluetooth keyboard for Mac Pro j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-26-2007 06:08 AM
Bluetooth and Wireless. Any issues with G5 and PT? Armando Pro Tools TDM Systems (Mac) 5 08-22-2004 03:08 PM
OT: Wireless keyboards - infrared vs. bluetooth clockface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2003 05:53 PM
