MOV import problem - strange!
I don't work with video a lot, but I'm trying to put together a DVD for a client and am running into a strange problem. When I import slightly longer MOV files, the imported video restarts suddenly.
For example, I have a 00:16:25 long mov file that I converted from a DV file. When I play the converted mov file in quicktime, it's fine. When I import it into protools, it plays fine until 00:11:40, at which point it suddenly cuts back to the beginning. In this case, the imported audio from video doesn't cut back with the video but continues seemlessly, out of sync with picture; in another case, both the imported video and audio "start over" together. All of the shorter mov files from the same project are importing fine, it's only those that are over 7 minutes. And again, when I view the mov files in quicktime, they're fine. I've tried re-converting the original DV files to mov's in quicktime, and the same thing happens once I import them into protools. I've also tried deleting the region in PT, renaming the MOV files and reimporting them - same thing. I'm running PT HD 8.0.1cs1 on a MacPro 2 X 2.8 Ghz Quad-core (OS 10.5.8.) Any suggestions? |
Re: MOV import problem - strange!
When you convert them to .mov are you still using the DV codec? I've always had problems with the DV codec in PT. PT seems to prefer Mjpeg B. If you transcode the file in quicktime to Mjpeg B it may fix the issue. You might need to take the quality down some because the file size will be much larger.
2009 Mac Pro Nehalem 2 X 2.26GHz Quad-Core Intel Xeon - OS 10.9.5 Mavericks - 128GB ram ProTools TDM HD6 - Magma Expansion Chasis - PT 10.3.8 and Avid I/O. ProTools 12.7.1.733 Macbook Pro 2.66GHz Intel Core 2 Duo OS 10.9.5 ProTools 12.7.1.733 Mbox2 PT 10.2 Scott Whittier Whittier Creative http://www.madmix.com/ www.voice123.com/scottwhittier |
DV codec? The DV codec is the preferred codec and by far is the most commonly used video codec DV is the primary codec of every recording device that uses firewire try to open the original file and make sure that you dont have a portion of the timeline selected ( select all ) just save the .DV file as .MOV but dont change the codec ( leave it as a DV ) if you have the option when exporting make sure its a self contained file cause this would explain why it stops at a certain point
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
That worked! Just opening the DV in quick-time and doing a "save as" worked ok for the movies that I couldn't get to work before. Only problem now is that the aspect ratio and quality are a little screwy. But at least the video doesn't randomly jump back to the beginning. Thanks!
Strange I/O behavior on import... | danander11 | General Discussion | 1 | 08-26-2010 08:18 PM |
Strange import audio problem. | lode | Pro Tools TDM Systems (Mac) | 2 | 06-08-2010 11:29 PM |
Audio Track Import? Strange looking | captainpat | Pro Tools M-Powered (Win) | 1 | 11-27-2006 06:41 AM |
Strange import error from Symphony v4 OMF... | Matt R | Post - Surround - Video | 5 | 06-19-2003 02:34 PM |
Strange Message After MIDI Import | lesbrunn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-12-2003 02:46 PM |
