Old 02-12-2020, 03:27 PM
benromsdahl benromsdahl is offline
Default Fix for DPI scaling issue causing additional errors
I have version 19.12 on a Win 10 system, NVIDIA GT710 graphics card.
When I attempt to fix the scaling issue in PT, the portion of waveform I highlight ends up on a different part of screen (plus the mouse cursor is tiny). Please see attachments for reference, they include my settings and a shot of the error.
Posting this is my last resort, I have been trying to solve this problem for months and my research has not led to a solution. Thanks for your help!
Old 02-12-2020, 04:26 PM
ChuckS ChuckS is offline
Default Re: Fix for DPI scaling issue causing additional errors
Assuming you have a high rez monitor and you were trying to make things bigger - a couple of things have changed in both PT and Win10 since Win10 arrived so you shouldn’t have to use compatibility mode and high dpi settings to fix scaling issues. Undo those settings for the PT executable and in Windows Display Settings, if you are scaling your display by a percentage other than 100%, set that to 100% and instead change Display Resolution.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-12-2020, 05:56 PM
I went ahead and tried changing resolution with no scaling and PT is too small. I scaled up 125% an PT is blurry (see photo). It would be fine if anyone knew of a fix to the bug in my original post.
Old 02-13-2020, 05:16 AM
What is your monitor's native resolution (HD,2K,4K)? Try setting a lower resolution in Display Settings that is a 1x or .5x multiple lower (i.e. if 4K set to 2K - 1920 x 1080). If scaling a percentage try 150% instead.
Old 02-13-2020, 03:28 PM
Native Resolution is 4k x 2k, 3840x2160
I have now changed it to 1080p, 1920x1080 in NVIDIA control panel as well as Windows settings.
Scaling in Windows at 125%
PT is still slightly blurry, but I can live with it, unless you know a better way.
Thanks again for your help Chuck!
Old 02-14-2020, 06:27 AM
It's the Windows scaling that's most likely causing the blur. If you get rid of that (set it to 100%) and PT still appears too small, try further reducing the display resolution in your Nvidia control panel. It's best if you let the video card driver handle it rather than Windows scaling.
Old 02-14-2020, 02:37 PM
I tried reducing display resolution in NVIDIA control panel while leaving scaling in Windows at 100% and it still didn't look much better. Maybe if I update my card in the future, but for now, I am ok with this. Thanks for the help!
Old 10-06-2020, 11:09 PM
GOOOTOOO GOOOTOOO is offline
Did you ever find a fix for this? My issue seems to be the opposite where I want protools smaller than the normal resolution, but everything I try just messes up other things.
Old 10-07-2020, 07:20 AM
ejinbc ejinbc is offline
OP
I had been trying to run two monitors on my system at 4K - and yes things got small. I found that I could adjust the dpi scaling BUT, I had to do the scaling after I launched Pro Tools AND then return to normal scaling before I quit Pro Tools. This would keep things working OK. If I did not do this (reset scaling before quitting Pro Tools) the next time I launched Pro Tools the scaling would be all messed up. This is a Pro Tools thingy.
Maybe that helps.
ejinbc.
Old 10-27-2020, 06:25 AM
polyh3dron polyh3dron is offline
This setting under the EXE file's properties should make the program usable with proper scaling active. Mind you, the mouse cursors will still be microscopic, and the GUI is still not going to look great, but it fixes the highlighting issue.
AIR plug-in scaling issue ewsmith89 Pro Tools 12 3 12-09-2016 01:33 PM
Protools 12.4 USB audio interface issue causing CPU and Video errors TristanBaylis Pro Tools 12 2 02-07-2016 06:30 AM
8.01 causing buffer underflow errors icenet Pro Tools M-Powered (Mac) 10 01-06-2010 05:06 PM
Quickpunch causing errors. jeremyml Pro Tools M-Powered (Win) 2 11-03-2009 11:28 PM
external ad/da causing -6085 errors req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-10-2008 06:13 AM
