Old 03-31-2008, 09:02 AM
dwayne00 dwayne00 is offline
Default need help with the S sound
I am using pt 7 on pc and i am having trouble while mixing a song with the s words. It becomes piercing to the ear but if I turn some of the highs down it takes away from the mix in that particular audio track.Is there a plugin i can use to stop this and how do I use it?
Old 03-31-2008, 09:06 AM
GunnyT GunnyT is offline
Default Re: need help with the S sound
Of course there is: it's called a De-esser.
You might also want to use a pop filter. That can contribute to the softening of the harsh sounding sibilance. (that's a tongue twister)
Where in the world is DJ Reggie?
Old 03-31-2008, 09:07 AM
M.Brane M.Brane is offline
Yes there is a plug for this. Strangely enough it's called a de-esser. You'll find it in the dynamics section since it's basically just a band-specific compressor.
Old 03-31-2008, 10:10 AM
thanks but how do you use it? Also can it be used on the master fader for the entire track?
Old 03-31-2008, 11:03 AM
TheLEM TheLEM is offline
I wouldnt use it on a master fader....but then again....we are in the business of trying anything once!!!
Next time you record: listen during the vox tracking to see if its a style thing...you may need to coach your singer a bit on mic. technique. If all else fails the De-esser can work miracles. Youll have to play around with it to get it to do what you want.
Old 03-31-2008, 11:55 AM
Stiff Stiff is offline
Try one of the presets of the Digirack de-esser on the vocal track. If it's not enough just change it a little. Be careful not to make the vocal lisp.
And yes... get a pop-filter or use the penn-trick!
Daily news & reviews
www.ProToolerBlog.com
Mbox Pro 3 master volume knob initial adjust jumps from no sound to sound : | Focuret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2012 04:45 PM
Audacity Sound, Reaper Sound, Pro Tools NO SOUND RoganX Pro Tools 10 3 03-18-2012 09:06 PM
MBox2Pro - Boot:No Sound; Disconnect/Reconnect Firewire: Get Sound; Why? mav9999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2009 08:48 PM
Skywalker Sound (Lucasfilm) Supervising Sound Editor Interview HDFilmtools Pro Tools TDM Systems (Mac) 0 10-02-2008 03:12 PM
MBox used as main sound card but sound is jerky Jonny5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-03-2006 08:42 AM
