Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-28-2021, 11:36 AM
unclevinky unclevinky is offline
Default HDX Hardware with Logic X
Hi.
so My mac 3.5 gig 6 core trash can is on 10.13.6 HIgh Sierra, I'm running ProTools Ultimate 20.12, just installed all the new HD drivers, etc, and am Attempting to Switch to Logic X. I can't for the life of me figure out why it won't play through HDX hardware. It shows up in audio prefs, I can select it, control the sample rate etc but no sound. Does anyone know if this will actually work? Thank you in Advance...Vj
Old 02-28-2021, 11:52 AM
syMPh syMPh is offline
Default Re: HDX Hardware with Logic X
check your mac os audio is not muted... when using logic the volume of the master volume of the core audio can affect ALL outputs on the hdx interface.
System Details
Old 02-28-2021, 12:42 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Exactly. Check Audio MIDI Setup > Audio then click on HDX.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-28-2021, 02:17 PM
Extreme Mixing Extreme Mixing is offline
I have been searching for the answer to this for weeks and even did a couple of songs with my Apollo Twin, since my PT hardware was unresponsive. Why would Avid change that preference for the new driver without any warning that is easy to find?
And yes, I did pose the question on this forum. These little issues can be maddening. Thanks for the assist!
Steve
Steve Shepherd
Extreme Mixing
Old 02-28-2021, 05:49 PM
Jeff, you were exactly right......Thank you so very much to you guys for the quick response.
Logic Pro 9.1 with TDM Hardware TornadoTed Pro Tools TDM Systems (Mac) 14 02-05-2023 02:25 PM
Logic Pro X and HD 192 Hardware DAS-Mike macOS 2 08-14-2014 09:44 AM
Logic with PT hardware gw sound Pro Tools TDM Systems (Mac) 23 09-15-2005 03:05 PM
Logic on HD Hardware K-Wolf Pro Tools TDM Systems (Mac) 4 12-30-2002 07:41 AM
Logic and PT hardware Lion Pro Tools TDM Systems (Mac) 1 12-15-1999 10:44 PM
