Old 12-09-2021, 12:36 PM
Tom Polce Tom Polce is offline
Default PTools 2021.12 HD Driver Problem
I just had to uninstall the new HD Driver and install the 2021.10 HD Driver for my HDX system to recognize my card and I/O. I'm using Ptools 20212.12 with 2021.10 HD Driver and it's working. I'm on a Mac Pro 2019 24 core running 11.6
Old 12-10-2021, 02:56 AM
Kaneepa Kaneepa is offline
Default Re: PTools 2021.12 HD Driver Problem
Having the same problem, since 2021.12 installation, HDX is not seen anymore by the system. Uninstalling 2021.12 HDX driver and installing 2021.10 or 2021.7 is not doing the trick for me!! PLEASE HELP!
Old 12-10-2021, 06:36 AM
innesireinar innesireinar is offline
No problems here.
2021.12
High Sierra
HDX
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 12-10-2021, 07:26 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
I had the same problem on our HDX-2 system. Wouldn't install earlier versions either. What I did do multiple times was run the un-installer for 12 multiple times. Odd thing is the first few times it didn't make me restart the Mac. The 4th time around it did, then I ran the un-installer again and another restart. After the last restart, I ran the installer and it took.
Makes no sense at all, even on our HD Native systems!! Two of them installed the driver the first time and another system wouldn't install it at all. Even going back to 10 or even 7 on that system wouldn't work after we tried 12, so we decided to just run v12 software using Core Audio to our Focusrite Red interface in that room... problem solved!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 12-10-2021, 10:49 AM
SDDP SDDP is offline
Originally Posted by innesireinar View Post
No problems here.
2021.12
High Sierra
HDX
I thought 2021 needs min OS Mojave?
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Old 12-10-2021, 11:00 AM
Yes I know, but it works.
Don't wanna spend for a graphic card on a 12 years old machine
Old 12-10-2021, 02:22 PM
Are you using it for any 5.1 mixes with 250+ voices and tons of plugs?
-OSX 12.7.2
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
Old 12-12-2021, 07:34 AM
strawb strawb is offline
same here. on Dec 08, 2021 - I installed 2021.12 PT and then 2021.12 HD driver - tried 3 times on my big sur system. called tech support. they walked me through a long process to uninstall 2021.12 HD driver (restart in recovery mode, terminal, etc.) took about 1.5 hours and finally 2021.10 HD driver reinstalled and all was ok (still running PT 2021.12 though). they told me to NOT install 2021.12 HD driver again until a fix was posted.
Old 12-12-2021, 08:06 AM
thierryd thierryd is offline
Runing tests on M1Max MacBookPro Mac OS 12.0.1 with PT2021.12 (not supported yet) and the 2021.12 HD driver is definitely causing issues... I had first installed it, ignoring the recommendations of going into recovery mode and that was a very bad idea (computer constantly jumping out of applications while you were typing). But even after doing everything right something is fishy...
I uninstalled it, but I still see weird behaviour. Trying to clipgain a quad-track audio file sends PT into spinning ball. I was running PT2021.10 (without installing the HD driver) quite stable.
Again non-supported configuration, but this is me testing outside studio envrionment...more testing needed...
http://www.a-sound.com/
Old 12-15-2021, 01:45 PM
nebosphere nebosphere is offline
Anyone know if there's any news on this or if Avid is planning on fixing soon? Sure would be nice!
HDX Driver No Longer Shows after 2021.10 Install Dizzi45Z Pro Tools 92 09-18-2022 11:59 AM
Pro Tools 2021.3 and 003 Family 11.1.5 Driver wdjudd Pro Tools 6 11-13-2021 01:49 AM
PSA: PT 2021.7 & HD Native Driver & Big Sur & Izotope RX7 milosziv Pro Tools HDX & HD Native Systems (Mac) 6 08-25-2021 07:36 PM
2021.6 HD Driver issues with Lynx Aurora 16 belolab Pro Tools HDX & HD Native Systems (Mac) 1 06-28-2021 06:18 PM
PTools Core Audio Driver (6.7) with Digital Perf? Willie Myers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2004 05:37 PM
