Assertion Bug when changing track views.
I'm experiencing an issue trying to change views on a Win7 64bit PC running PT 11.2.1 I've imported a relatively large number of clips from a (externally recorded) drum session, 6-7 takes on each mic, 10 mics in total, so I end up with 10 channels, each with 6-7 clips on each. I'm trying to move the "good" clips to different playlists so I can toggle between them, but keep running into an issue. I start by grouping my channels together and then attempt to move clips from the main track onto new playlists. I know there are many ways to do this, but this seemed to be the quickest: 1) Switch to the playlist view using Shift+Win+Left/Right - all the channels change to playlist view (as expected) 2) I then drag one of the clips underneath the main playlist - this creates a new playlist containing the moved clip. Because the tracks are all grouped together, the change happens on all channels. 3) Select the new playlist from the dropdown list on any of the drum channels. The main playlist is now the newly created one... 4) Try to switch back to waveform view using Shift+Win+Left/Right I then get a number of access violation errors, plus some messages along the lines of Could not complete the Select All command because Assertion in "e:\ code\ 139106\ protools\ newfilelibs\ time\ Time_TypedBase.h", line 140 Is this unique to me, or is there a bug here? I can replicate is quite easily with only 2 channels and 2 clips involved... My workaround has been to do this the 'classic' way: cut the clip I wish to move to a new playlist, manually create the new playlist (Win+\), then paste into it. Any thoughts much appreciated! Thanks, benw |
changing sends assignment views | jackp | Pro Tools TDM Systems (Mac) | 0 | 10-21-2012 09:13 PM |
Shortcuts between midi track views | Jussi | MIDI | 0 | 05-07-2007 11:44 AM |
HOW TO QUICK CHANGE TRACK VIEWS | smc917 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-13-2004 10:36 PM |
Track Parameters and Track Views not in Sync | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-29-2002 04:18 PM |
Toggling Track Views w/ProControl | Borgbilly | ProControl, Control|24, Command|8 | 5 | 12-21-2001 09:52 AM |
