Old 10-31-2011, 06:17 AM
daeron80 daeron80 is offline
Default Re: Quick Punch Glitch Still Exists
Vote for the fix here. I mean, it's sort of like voting for Microsoft to fix an error in Word that randomly changes the first and last letters of some sentences, right? But maybe it'll help draw more attention to it.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-31-2011, 01:45 PM
Battles Battles is offline
Voted!
Old 10-31-2011, 05:58 PM
Zenman Zenman is offline
Default
Originally Posted by Raw-Tracks View Post
I don't ever get a glitch that's recorded. It's only in the monitoring while punching. It's not the VIA chipset either. I installed a card with a TI chipset tonight, no difference.
Come on AVID, get it together! This is not a small issue. I do hundreds, if not thousands, of punches throughout the course of producing an album and neither I, nor my clients, appreciate hearing this glitch!! Get it together please.
Yes, that's also my experience. The recorded region remains unaffected. It's kind of like a tiny delay and the recording artist shouldn't have to put up with it. It happens regardless of whether I punch using the control surface or the mouse on the computer monitor. Don't recall being an issue in any other version starting @ v6. It also happens when you flag using pre-roll. It's not just a "punch-in" issue as such.
Old 11-09-2011, 01:51 PM
Raw-Tracks Raw-Tracks is offline
Would love an update from Avid on this issue.
Eric
Practice Your Mixing Skills
Download Our Multi-Track Masters
www.Raw-Tracks.com
Old 11-10-2011, 11:15 AM
Gammon2006 Gammon2006 is offline
I would also love an update. The clicks are sometimes frighteningly loud and they're really distracting for clients. I just switched from Mac to PC (because my hackintosh died) and from PT 9 to PT10. I've never encountered this issue before now, so I tried a few things to see if I could make it go away. Here's what I can tell you about when it happens/doesn't happen, which I hope will be helpful to Avid tech support:
1. PT 9.0.3, OSX 10.6.7, RME Fireface 400: no issues
2. PT 10, Windows 7 SP1, FF400: ISSUES
- it appears that if I turn off ADC, the issue largely goes away
3. PT 10, Windows7 SP1, Profire 2626: no issues
So I think it has something to do with Windows, some third-party ASIO drivers, and recording while ADC is enabled. There you go, now please fix it so that I can go back to my FF400 and 64 sample buffer. Thank you.
P.S. - how come when I bounce a section of a track and import it to the same location, it's not at the same spot? It's moved by a large number of samples. Is that an ADC problem too?
  #16
Old 11-10-2011, 11:47 AM
Thanks, but I've got it on Digi 002R with and without ADC enabled. Not just the noise in the monitors, but a click written to the audio on disc; I suspect it sometimes writes the data out of sync, or that it's always a bit out of sync, sometimes more than others. The issue of writing data out of sync has been with us since 8.x.
Could be, but most like the same bug.
David J. Finnamore
  #17
Old 11-11-2011, 11:23 PM
jeam25's Avatar
jeam25 jeam25 is online now
This issue is a driver or firmware issue . Jo de lucca and myself
made a lot of troubleshotting on this and everythign pointed to that .
To make things worse hes using now an RME hardware and everything.runs perfect.
And i tested the same system with same plugs and same setting but with the cheapest
fast track from m audio and i didnt got any of the mentioned
bugs....... everything worked just perfect .
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
  #18
Old 11-12-2011, 12:56 PM
So the workaround is to buy a non-Avid or really chincy Avid interface?
David J. Finnamore
  #19
Old 11-12-2011, 01:03 PM
Yes, I believe you are correct. I too have done a lot of troubleshooting on this. The last driver to not exhibit this problem is the 8.0.3 beta driver for Win 64.
  #20
Old 11-12-2011, 01:50 PM
i have an rme fireface 800 and have got this glitch in ALL releases of 9 as well as 10. it was more subtle and not as frequent in 9.03 but still there.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Quick punch.... can't hear track audio until I punch in stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-31-2017 02:11 AM
Strange MIDI punch in glitch--PT TDM/HD 7.3.1cs4 jfredk Pro Tools TDM Systems (Mac) 3 10-13-2007 10:58 PM
Punch Recording Glitch Issue tmoc-rocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-14-2004 01:26 PM
Punch in Clicking Glitch sound rrhodes1 Pro Tools TDM Systems (Mac) 5 09-04-2003 11:45 AM
quick punch jaysun Pro Tools TDM Systems (Mac) 9 09-10-2002 12:44 AM
