Is this cpu compatible with Pro Tools 9 ? Sandra Report included
Everytime I try to drag a wav file from workspace to the arrange window,I have loud blasts of noise when playing back the wav file, or either get 9301 error messages.Or messages saying that the file cannot be played back due to cpu/hard disk issues.. this is a very powerful i7 cpu with non issues in other daws. any help would be appreciated.. thank you
Is this cpu compatible with PRO TOOLS 9? SiSoftware Sandra Audio Interface - Focusrite Saffire 24 DSP firewire OS - win7 sp1 x64 12gb ram Pro Tools - 9.05 same thing happened with earlier versions as well. SiSoftware Sandra Computer Model : GigaByte X58A-UD3R Processor Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz Speed : 3.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte X58A-UD3R BIOS : Award (OEM) FF 02/18/2011 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 798MHz (1.6GHz) Memory Module(s) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : ATI Radeon HD 5700 Series (SM5.0 850MHz, 1GB DDR5 4.8GHz 128-bit, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 5700 Series (SM5.0 850MHz, 1GB DDR5 4.8GHz 128-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : ATI Radeon HD 5700 Series (850MHz, 1GB DDR5 4.8GHz 128-bit) STREAM GP Processor : ATI Radeon HD 5700 Series (850MHz) Storage Devices WDC WD1500AHFD-00RAR5 (150GB, SATA150, 3.5", 10000rpm, 16MB Cache) : 140GB Seagate ST95005620AS (500.1GB, SATA300, 2.5", 7200rpm) : 466GB (C:) SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (E:) WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache) : 932GB (G:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) WDC WD5000YS-01MPB0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (F:) Seagate ST3750330AS (750.2GB, SATA300, 3.5", 7200rpm) : 699GB (H:) Seagate ST3500630AS (500.1GB, USB2/SATA150, 3.5", 16MB Cache) : 466GB (K:) Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (A:) Logical Storage Devices Windows 7 (C:) : 466GB (NTFS) @ Seagate ST95005620AS (500.1GB, SATA300, 2.5", 7200rpm) Apps+Vst (E:) : 466GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Audio HD (G:) : 932GB (NTFS) @ WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache) Samples HD (D:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Projects (F:) : 466GB (NTFS) @ WDC WD5000YS-01MPB0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Music (H:) : 699GB (NTFS) @ Seagate ST3750330AS (750.2GB, SATA300, 3.5", 7200rpm) Downloads (K:) : 466GB (NTFS) @ Seagate ST3500630AS (500.1GB, USB2/SATA150, 3.5", 16MB Cache) Optical Drive (A:) : N/A @ Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : Giga-Byte EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Giga-Byte 6 port SATA AHCI Controller Disk Controller : Giga-Byte 88SE9128 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Creative Labs Audigy 2 Firewire Controller FireWire/1394 Controller 2 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: Is this cpu compatible with Pro Tools 9 ? Sandra Report included
As I noted in another thread these cpu parts we're hand picked based upon my mac pro cpu hardware parts,since with my mac pro, I don't have these issues.. I would think with the same hardware everything would work similar.. I don't understand why Pro tools on win7 would have errors if the hardware is exactly the same as the mac's..
What's really strange is maybe off topic,is with any other daw I've tried on win7,this i7 completely rocks,and I never had one issue with playback of wav files,in other daws.. is Pro Tools really coded specifically to certain tweaks? I've tried all the ones offered by AVID fwiw.. Can someone offer any sort of options to try here? I've got clean hard disks and they are defragged (again no issues when on my mac with similar hardware.) |
Bump this for the gurus of protools or digi support.. have a session today and would love to get a fix before we start,or I'm afraid my my clients will be unhappy..
you trashed pref's and all the usual's? Things i can think of that would make it run differently on windows would be file system (NTFS vs HFS+), memory and memory timings, problems with the explorer context menues (mac drive has caused this prob for me in the past. Re-installing fix's) and the big one is drivers.
Dont think your CPU is the problem but i could be wrong. |
thanks, tried trashing prefs, are there any other idea's?
Is there a certain way I should format my hard drive for pro tools on pc? certain cluster size? |
So I disabled my network card
formatted a hard drive NTFS to cluster size of 32kb trashed my prefs have tried all of the pro tools tweaks advised by avid. still getting the white bursts of noise.. this is totally embarrassing,i've read threads to where people still have this same issue,and it's been going on since PT7 So what else to do I do here? Please let me know, I can't record audio in pro tools or even use the supplied content offered for loops and such if the playback keeps doing this... Again on my mac there are none of these issues.. what do you recommend? I'm thinking of tracking with another daw today,because I don't wanna run off my clients with this issue.. Any other advise?? |
Due to the history between Pro Tools and Sound Blaster, I would remove this:
FireWire/1394 Controller 1 : Creative Labs Audigy 2 Firewire Controller and all but 2 hard drives until you reach solid footing(performance). Removing anything that is not absolutely needed for function will help make troubleshooting easier. You might even pull half the RAM(and make sure that the 3 remaining sticks are in the proper 3 slots for triple-channel operation) just to see if it helps(my local Avid dealer/system builder swears that 6-8GB of RAM is the sweet spot). FWIW, I have a very similar build(i7 950 on GigaByte X58A-UD3R) that has yet to be solid(still running with my older i7 920 on GigaByte X58-UD3R). Also, check for the latest BIOS and try manual RAM timings instead of the Auto setting.
thanks again |
Hi Bobby, are you sure its hardware related? Is it possible that the file you are dragging in has funky header info that would cause these bursts. I had a DAW system once that could not stand header data and I had to use stripwave on the files before import.
Have you tried different wav files, do they all act the same? Good luck Rob |
Avid can and does built Pro Tools to work with all, or most all CPU builds, if you have a Mac. The reason is, there is very little choice in monolithic Macland, which makes it a lot easier to code a program to work with the hardware configurations since there is little variation. In anarchic Windowsland, there are so many variations in hardware components and builds that it's not nearly as easy to code a program that works well with every possible combination of CPU, RAM, motherboard, motherboard chipset, firewire chipset, hard drives and on and on. That's why it's so helpful to have the pioneers in the i7 thread and before that the Best Desktops For Pro Tools thread and farther back Allan Hallada and the others who blazed a trail for AMD with Pro Tools. And Pro Tools isn't the only DAW with issues. They each have problems and strengths and weaknesses themselves and with the hardware they will work with. The just works DAW these days seems to be Reaper. As always YMMV. Cheers,
Laptop Compatibility for Pro Tools SANDRA REPORT INCLUDED | Richard621 | Windows | 4 | 04-01-2013 10:07 PM |
Pt9.0.5 Help Please (Sandra Report Included) | msuk | Windows | 2 | 09-25-2011 08:48 AM |
Pro tools 9 choppy playback sandra report included | daniel101 | Pro Tools 9 | 1 | 06-11-2011 11:58 PM |
Three problems since 8.0.4 - Sandra report included. | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-22-2010 10:44 AM |
Need Help Debugging PC - SANDRA Report Included | EarBud | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-23-2010 07:09 PM |
