Old 11-17-2008, 04:21 PM
salmonsound salmonsound is offline
Default MIDI Input Problem - Selected Track vs Record Enabled
Can I control the function in PTLE 7.4 that enables midi input when the instrument track is selected? Sometimes I'm only able to get midi input when the track is record enabled.
Recording # Editing # Mixing # Mastering
SALMON SOUND
Studio # Mobile # Online
http://www.salmonsound.com
Old 11-17-2008, 05:42 PM
flommer flommer is offline
Default Re: MIDI Input Problem - Selected Track vs Record Enabled
Hmmm.. Your description of the problem is pretty short, but I'll describe what happens on my rig..
I have a couple inst tracks, inputs set to "all", a VI inserted on each.
If I select 1, then my controller triggers it. If I then select 2, the controller then triggers 2. If I then shift select 1, the controller only triggers 1.. No matter what order I shift select the tracks in, only 1 triggers..
If I then Rec enable 1, track 1 is triggered. If I then Rec enable 2, 1 is no longer rec enabled and the controller triggers2. If I shift Rec enable 1 and 2, the controller triggers BOTH 1 and 2.. When I disable record on both, then it is back to the way it worked with just selecting..
The only 2 options that I have seen that might affect this are "MIDI Thru", which I have selected, and an option in preferences>MIDI>Default thru instrument.. I have this set at "First selected midi track" This was the system default setting, I believe..
Are you saying your rig is not working this way?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 12-28-2008, 07:42 AM
Yes, it's not working that way. It seems like I have a bug or something.
It works like yours most of the time, but sometimes when I select an inst track with a VI it does not trigger. I must rec enable the track for it to trigger. Other times it will trigger if selected only. I don't know how to fix this. If I create a new session and use a session where this problem did NOT exist as the template, the problem will not be there in the new session. If I create a new session from scratch, the problem may or may not be there.
Thanks for the reply, I'm going to look into the things you said.
SALMON SOUND
BUG? selecting midi track arms record for selected track browniespeaks Windows 40 06-10-2013 11:41 AM
No output from midi on audio track record enabled. supergirl36 MIDI 3 08-21-2011 04:22 PM
Shift + Option + Record Enable not working with MIDI and Audio Track selected, why??? enzomolinari Pro Tools 9 0 07-20-2011 07:00 AM
Master Track & Input Track LED peak when record enabled sharptoothyouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2009 02:11 PM
Midi track meter dead,record enabled,data recordin coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2004 07:52 AM
