Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 07-11-2020, 11:03 AM
emf1138 emf1138 is offline
Default Really getting frustrated
I had a previous thread about all the issues with an older Focusrite scarlett causing pop and glitches. After exhausting the troubleshooting options, I ended up buying a new UA Apollo twin, thinking the Scarlett was crapping out. Welp, the pops and glitches are still happening! What could I be missing? I have brand new JBL 308ps and new TRS cables going to the apollo from the jbls. What else could be causing these hiccups??!
2013 Mac Pro, PT 2019.10, 10.13.4, Glyph USB 3 drives. I've tried various cache sizes and HW buffers too.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 07-13-2020, 06:11 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Really getting frustrated
I'm not the biggest authority on Macs, but have you tried the UA troubleshooting/optimization tips for Macs?
High Sierra Compatibility Info
Mac-Pro Late 2013 Thunderbolt Optimization
Will K
System Details
Old 07-13-2020, 07:43 AM
JFreak's Avatar
JFreak JFreak is offline
Scarlett is USB interface and you are using USB drives, so maybe you could try copying a test session to internal SSD of your Mac Pro and disconnect the USB drives. See if it hiccups with less USB traffic.
Janne
Old 07-13-2020, 07:54 AM
Why start another thread when there was some useful info in the other thread?
Here is the previous thread. http://duc.avid.com/showthread.php?t=410781
If the click and pops are only happening on payback only, and not recorded in the DAW are are they coming from the DAW or something downstream?
Is it a bad cable/electrical connection? Did you try wiggling all the cables/connections? Bad headphones, or monitors, something nearby causing RF interference, something not so nearby causing interference and travelling on the power cables (fluorescent lights flickering, a refrigerator or other motor starting up), try getting *everything* disconnect you don't need (monitors/speakers, cables, disk drives, unneeded external video monitors, etc). Try with headphones only, try different phones, or if you don't have any try monitors only. Try headphones connected to the trashcan with Built-In Output and everything else removed.
What happens when you checked using Built-In Output as the playback engine? I think I asked that twice in the other thread.
If it's not downstream from the DAW then I would try a minimal Pro Tools system with base plugins installed only, starting with empty sessions, etc.
Old 07-13-2020, 10:34 AM
I believe I did mention that with the scarlett device I did run a 1 track stereo session with no plug-ins and it was still popping and clicking, though not as bad. Haven't tried that with the UA. Didn't give the built-in a shot yet.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
  #16
Old 07-13-2020, 10:39 AM
I don't mean just no plugins in the session. I mean you troubleshoot this "properly" by moving all .aaxplugin files out of the plugin folder and trashing prefs and trying with just the standard Pro Tools plugins installed. A very quick test and the best way of excluding third party plugins.
  #17
Old 07-13-2020, 10:40 AM
JFreak's Avatar
What he said. It is important, because PT loads all plugins into memory and even if your session is not using a bad plugin, one bad plugin loaded into memory can cause all kinds of random issues.
Janne
  #18
Old 07-13-2020, 11:04 AM
What you are trying to do is make big bold steps to try to triangulate the problem. e.g. is it downstream of the DAW or if it's in the DAW is it a plugin etc... rare for clicks and pops there not to be caught and cause errors, but if it's happening it's possibly a plugin.
And if it's coming from the DAW and not a plugin and not fixed by trashing prefs, and trying new empty sessions etc. then you could spend forever trying to track it down. Instead of that I'd tend to go for broke at that point. Do a full clean test install of macOS in a container on the boot drive if there is space or on a spare external SSD. Install Pro Tools and ILM only and fully optimize the machine again.. and test with built-in output.
  #19
Old 07-13-2020, 11:40 AM
Default Re: Scarlett 2i4 pops/drops/clicks
Got it.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Crackles and Pops in PT 11.2.1 w/Scarlett 18i8 BassGuyGG Pro Tools 11 1 04-06-2017 11:18 AM
Help!! Clicks and Pops at 96k RCN Pro Tools TDM Systems (Mac) 7 09-16-2012 06:19 AM
Pops & clicks 8.0.3 rotoboy Pro Tools TDM Systems (Mac) 36 03-19-2010 02:52 PM
clicks and pops RustbeltDan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2007 07:52 PM
pops and clicks chahende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2006 09:21 AM
