Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 07-12-2013, 03:57 AM
crizdee's Avatar
crizdee crizdee is offline
Default Bomb Factory BF76 Ratio very slow operation FIXED!
UPDATE! Found i had 2 versions in the plugins folder! put the BF plugs in a separate folder then forgot when updated to 10.3.6
when switching between ratios on the BF76 it is taking ages and getting the SWOD spinning wheel of death for several seconds! everything else is operating as normal!
anyone else seeing this?
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-12-2013, 09:42 AM
guatamas guatamas is offline
Default Re: Bomb Factory BF76 Ratio very slow operation FIXED!
I noticed that some other plugins are already AAX, like BF76 and have both dpm and aax files on the computer.
I checked the plugin folder for AAX location and moved the already converted dpm files of the same plugins to the unused folder. Some housekeeping so to speak.
Bomb Factory BF76 release kje Pro Tools TDM Systems (Mac) 2 04-13-2011 03:24 PM
Advise on Bomb Factory plugs: BF76, BF3A, 660, 670 cc1 Pro Tools TDM Systems (Mac) 1 07-12-2004 08:34 PM
le factory bundle bomb factory+ plugins... jstimulus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-12-2004 06:52 PM
Bomb Factory LA-2A and Bomb Factory 1176 Anton P Pro Tools TDM Systems (Mac) 13 02-29-2004 08:30 AM
how to authorise Bomb Factory plugins w/ Factory 001 bundle MGalway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2002 10:34 AM
