Old 01-01-2009, 01:14 PM
Mix Master Factories Mix Master Factories is offline
Default Noise and hum!? (SOLVED)
EDIT! PROBLEM SOLVED, it was my monitor. As soon as I connected the VGA cable the noise appeared.
When I connected my emulated speaker line out (from the amp) to my Mbox I got some noise and a pretty loud hum around 465hz. I didn't even have to turn on the amp. When I removed the amp from the electrical socket the noise died out. But as soon as I plugged it back in the noise returned (I tried different outlets).
The noise ONLY starts once I start Pro Tools. It's pretty quiet with the Mbox turned on, but with Pro Tools not running.
A fun little fact I noticed was that if I plugged it in the Mbox line in jack-input, most of the hum was diverted to the speaker of the amp. If I plugged it into the XLR input on the Mbox the speaker would go quiet and noise came from Pro Tools.
This hum was not present when I connected the same devices on my Acer laptop running Windows and PT 7.2.
Any ideas?
Specs:
Macbook Pro
Mbox 2
PT8.0
Noise problems on MacBook Pro (solved) P Heist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-05-2009 01:55 PM
Mysterious noise problem finally solved! gonzolagonda Pro Tools TDM Systems (Mac) 0 09-03-2008 05:35 AM
The way I solved the 'Mbox noise' Matt_Maestro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-28-2003 07:39 AM
MBox noise solved!! Flamethrower 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-22-2003 02:00 AM
882 noise problem solved? tino Pro Tools TDM Systems (Mac) 1 02-05-2000 01:20 PM
