CPU load changes with PT10
For those of you that have upgraded from 9 to 10, could you please share your experience/observations with CPU load improvements? If so, could you please quantity (ex. reduced from X% to Y% with the same file)? Also, if you could please list the bit and sample rates you are using? This would be most appreciated for those of us still on the fence for justifying the upgrade price.
Re: CPU load changes with PT10
kw88keys,
I cannot give you the exact figures as you requested since I have already upgraded both of my ProTools PCs with version 10. I will say this, i have 2 older machines (dual core) running with 4GB of RAM. After upgrading, I pulled up my 3 latest sessions and found the CPU (RTAS) utilization was actually 2-3 percent higher than was the case with version 9. I did not note a siginficant difference but it was unfortunately not an improvement. I have just ordered a quad core processor, motherboard and RAM so I do not expect this to be an issue for me, but wanted to provide you with some feedback. |
My sessions are 44.1khz - 24bit.
Thanks very much for the reply. I was hoping for better...
I am seeing near identical CPU usage from 9 to 10.
CPU load shouldn't change much between Pro Tools 9 and 10 - some may see slightly better performance, some may see slightly worse depending on several factors like the number and types of plug-ins used, fades used in the session, etc.
All in all our testing shows it's about even. |
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" | J-Xile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-14-2015 08:36 PM |
PT10 Cross grade won't load | Maars | macOS | 4 | 03-19-2013 02:47 PM |
Pro Tools 10 & Edirol UA-25ex - can't load PT10?! | hooks4hands | Windows | 4 | 01-03-2013 10:18 AM |
PT10 CPU Load? | WKG | Pro Tools 10 | 5 | 10-24-2011 11:03 PM |
PT10-does it load to ram or not on LE version? | PMoshay | macOS | 2 | 10-23-2011 04:56 AM |
