Input in ProTools set to Mac internal mic ?
Ok.
So after an extremely frustrating past few days of downloading drivers, uninstalling Protools, reinstalling protools, installing updates, restarting etc. I finally got my Mbox to turn on without crashing My OS X 10.7.2 (after stumbling upon a link in this forum for a driver update for Pro Tools 10 ) However when I restarted and opened a new session the I/0 was set to the macs internal mic. Soooo I set the Mbox both as my input and output in the system preferences and restarted for good measure. Again I found the same problem. Got signal at the Mbox but it had no analog inputs in pro tools. Just the internal mic. Searched the forums for the past hour and a half and have found nothing. I decided to try uninstalling ProTools and re-installing. Only to find that pro tools gets to the final minute of install and either freezes or won't finish. I suppose the questions I need answered are. 1. How do I change the I/0 to be the Mbox 3 and not the Mac internal mic ? 2. Will I be able to reinstall Protools 10 from the email I received? (as pro tools 9 won't run on Mac 0SX 10.7) 3. Am I completely screwed ? Im about ready to throw this Mbox and pro tools directly in the trash & never look back. Any help would be greatly appreciated. |
Re: Input in ProTools set to Mac internal mic ?
As mentioned, hold the N key down while launching Protools. You usually have to do this the first time after installing, or re-installing Protools. After that it should be fine.
Also, once you open up a Protools session, go to the I/O setup, and click "Default" on all tabs (input, output, bus, inserts). That's because the I/O setup is still thinking you're using the last setup, which was your internal Mac mic, until you tell it otherwise. |
Go into i/o Setup and click Default for Inputs and Outputs.
Using Internal Sound card for playback Protools 10 | jwg1018 | macOS | 3 | 08-19-2013 05:17 AM |
Protools 10 playback via 24io and/or internal sound card | jwg1018 | macOS | 2 | 09-04-2012 08:54 AM |
How can I monitor internal mac audio while protools is running? | BCR40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-29-2008 02:20 AM |
Alt SRC input internal routing on 002r | crazyfoo' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2006 06:12 AM |
PT LE Internal Input Gain? | GrimCoffee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 37 | 07-02-2005 01:52 PM |
