GUI Scaling problem on W10
It looks like PT 12.2 & 12.3 are not scaling properly on Windows 10
I am using a resolution of 2560x1440 at 125% scaling and never had a problem with this on PT until now. Basically, if the option "Disable display scaling on high DPI settings" is checked the GUI will look quite small and hard to look at. The only benefit is that the text will look sharper. If the option is unchecked it will look as usual until a plugin from AIR Music Technology (only this ones as far I know) is opened the GUI will become unscaled and everything will look small like if the scaling option was disabled when is not. For now, I think the unique workaround is to go back to an earlier version of PT 12 where this errors aren't there or just not to use the plugins that cause this problem, also changing the resolution of the screen can be an option until Avid decides to fix this. Unscaled GUI http://imagizer.imageshack.us/a/img903/6260/S9wJbu.png http://imagizer.imageshack.us/a/img910/3598/kVb7G0.png Normal GUI http://imagizer.imageshack.us/a/img911/3279/fs48G7.png http://imagizer.imageshack.us/a/img910/4228/DKrTRv.png Last edited by APM; 11-09-2015 at 12:57 PM. |
Re: GUI Scaling problem on W10
I think I've encountered something similar. Running PT 12.8.2 on an HP Spectre
SiSoftware Sandra ID Host Name : Fulbright-D Workgroup : WORKGROUP Computer Model : HP Spectre x360 Convertible 15-bl0XX 103C_5335KV HP Spectre Serial Number : 5CD73***** Chassis : HP Mainboard : HP 82C1 Serial Number : PGHLF01******* BIOS : AMI (OEM) F.10 04/19/2017 TPM - Trusted Platform Module : IFX SLB9665 2.00 (PCR 24) Intel vPro : 11.06.00.1121 Total Memory : 16GB SO-DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz (2C 4T 3.5GHz, 3.3GHz IMC, 2x 256kB L2, 4MB L3) Socket/Slot : FC BGA1356 Chipset Memory Controller : HP Core (Kabylake-U) ULV Host Bridge/DRAM Registers 100MHz, 2x 8GB SO-DIMM DDR4 2.13GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : 8ATF1G64HZ-2G3B1 8GB SO-DIMM DDR4 PC4-19200U DDR4-2400 Memory Module : 8ATF1G64HZ-2G3B1 8GB SO-DIMM DDR4 PC4-19200U DDR4-2400 Video System Monitor/Panel : BOE Generic PnP Monitor (3840x2160, 15.6") Video Adapter : Intel(R) HD Graphics 620 (24CU 192SP SM5.0 1GHz, 768kB L2, 2GB DDR4 2.13GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL : nVidia GeForce 940MX (384SP 3C 1.19GHz, 48kB L2, 2GB) OpenCL : Intel(R) HD Graphics 620 (192SP 24C 1GHz, 512kB L2, 6.4GB DDR4 2.13GHz 128-bit, Integrated Graphics) DirectX 11 Device(s) : NVIDIA GeForce 940MX (2GB) DirectX 11 Device(s) : Intel(R) HD Graphics 620 (192SP 24C 1GHz, 768kB L2, 128MB DDR4 2.13GHz 128-bit, Integrated Graphics) OpenGL : GeForce 940MX/PCIe/SSE2 (2GB) Pen and Touch Touch Digitiser : Integrated Multi-Touch : Yes Simultaneous Touches : 10 Pen Digitiser : Integrated Storage Devices SAMSUNG MZVLW512HMJP-000H1 (512.1GB, PCIe3x4/NVMe, M.2, SSD, SED) : 477GB (C:) (D:) Logical Storage Devices Windows (C:) : 464GB (NTFS, 4kB) @ SAMSUNG MZVLW512HMJP-000H1 (512.1GB, PCIe3x4/NVMe, M.2, SSD, SED) RECOVERY (D:) : 11GB (NTFS, 4kB) @ SAMSUNG MZVLW512HMJP-000H1 (512.1GB, PCIe3x4/NVMe, M.2, SSD, SED) Hard Disk : 256MB (FAT32, 4kB) @ SAMSUNG MZVLW512HMJP-000H1 (512.1GB, PCIe3x4/NVMe, M.2, SSD, SED) Windows RE tools : 980MB (NTFS, 4kB) @ SAMSUNG MZVLW512HMJP-000H1 (512.1GB, PCIe3x4/NVMe, M.2, SSD, SED) Peripherals LPC Hub Controller #1 : HP Sunrise Point-LP LPC Controller Audio Device : HP Sunrise Point-LP HD Audio Disk Controller : HP Sunrise Point-LP PMC Disk Controller : Samsung NVMe SSD Controller SM961/PM961 USB Controller #1 : HP Sunrise Point-LP USB 3.0 xHCI Controller SMBus/i2c Controller #1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Printer : HP Delivery Driver V4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Sensors Motion : Intel Gyrometer Sensor (Motion, Gyrometer) Unknown : Intel Lid Closed Detection Sensor (Unknown, Unknown) Unknown : Intel Shake Gesture Sensor (Unknown, Unknown) Unknown : Intel Pan Zoom Gesture Sensor (Unknown, Unknown) Unknown : ST_MICRO Physical Magnetometer Sensor (Unknown, Unknown) Orientation : Intel Inclinometer Sensor (Orientation, Inclinometer) Unknown : Intel Step Detector Sensor (Unknown, Unknown) Unknown : ST_MICRO Physical Accelerometer Sensor (Unknown, Unknown) Unknown : Intel Hinge Sensor (Unknown, Unknown) Unknown : Intel Flick Gesture Sensor (Unknown, Unknown) Unknown : Intel Device Movement Sensor (Unknown, Unknown) Unknown : Intel Instant Activity Sensor (Unknown, Unknown) Unknown : Intel Tap Gesture Sensor (Unknown, Unknown) Unknown : Intel Uncalib Gyrometer Sensor (Unknown, Unknown) Orientation : Intel Geomagnetic Orientation Sensor (Orientation, Unknown) Unknown : Intel Lid Mode Sensor (Unknown, Unknown) Motion : Intel Accelerometer Sensor (Motion, Accelerometer) Unknown : Intel Significant Motion Sensor (Unknown, Unknown) Unknown : ST_MICRO Physical Accelerometer Sensor (Unknown, Unknown) Unknown : Intel Uncalib Magnetometer Sensor (Unknown, Unknown) Orientation : Intel Simple Orientation Sensor (Orientation, Unknown) Orientation : Intel Compass Sensor (Orientation, Compass) Unknown : Intel Magnetometer Sensor (Unknown, Unknown) Orientation : Intel Orientation Sensor (Orientation, Unknown) Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Wireless Adapter : Intel(R) Dual Band Wireless-AC 8265 (802.11n (HT), AES-CCMP, 144.4Mbps) Power Management Battery #1 : Hewlett-Packard Primary 77.25Wh/5.88Ah Operating System Windows System : Microsoft Windows 10 Personal 10.00.16299 Platform Compliance : x64 =============================================== Text in PT has become so small I need a magnifying glass to read it. And the menu bar across the top of the window has all but disappeared. Nearly impossible to access the menus. I tried changing the screen res/scaling which helped only marginally, but the menus are still not clearly visible. |
Automation Scaling | Arya44 | Tips & Tricks | 4 | 02-19-2020 09:08 AM |
Protools multicore scaling | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-01-2008 11:31 AM |
Scaling MIDI data | Brent1515 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-27-2007 05:06 PM |
MIDI scaling - new behaviour in 7.1cs2 - bug? | jeremyroberts | Pro Tools TDM Systems (Mac) | 1 | 12-21-2005 03:12 PM |
Automation Scaling? | decibel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-13-2002 12:20 AM |
