  #21
Old 08-17-2013, 01:41 AM
Focuret Focuret is offline
Default Re: All Artist Mix won't power on users...come on in.
Originally Posted by ArKay99 View Post
Note to those who've had this failure, or are just experiencing it now, if you checked the power plug did it seem 'loose' or not fully inserted into the socket?
Just checked; not loose.
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
  #22
Old 08-17-2013, 08:32 PM
Talked to Avid's guy in Beijing. He said this
Yes, I have handled several similar issues with Artist control and Mix. Then our QA team found out there was defect on the choker. It was fixed in the next revision.
Not sure what the choker is but apparently those of us that got screwed were victims of crappy units that has since been fixed. So new buyers shouldn't experience this issue, I suppose.
  #23
Old 08-29-2013, 10:53 PM
ArKay99 ArKay99 is offline
Sorry I ddin't see this until now. Here is your answer.
From post #17 in this thread.
Well, I think I've found the part. It's a Laird CM3312R111R-10. It's a an SMD common mode choke chip. It's a very unique package. I looked at over 2000 pictures of other components and this is the ONLY part with the footprint and terminal layout.
HOWEVER...according to Digi-Key the part is obsolete and they have none in stock and can't get any more. I haven't checked other distributors.
I took the cover off my mix to verify the part and found something I didn't expect. There was a new and different part in place of L7 and L8. They were bigger and appear more robust and there was a bit of trace rework. This can mean one of 2 things.
1: The part that was in there originally was indeed the Laird part and it is indeed obsolete and AVID had to substitute the parts in there just to get it to work again.
2: what was said in #1 above AND these parts and the rework was done to address the issue many have been having with the Mix and this was part of an ECO.
If 2 is the case, anyone sending the unit back for repair should have a more reliable Mix in the future.
I'm keeping my router earthed and my Mix PSU IEC plug lashed to the PSU anyway.
Hope this helps.
This seems to confirm what your guy said here.
If you can send it somewhere to be repaired, I think the ECO is in place to change out the defective 'choke' (L7 and L8) on the power input. So instead of putting in a doomed part they will shoehorn a new more robust part in it's place...at least as far as I can tell with my unit.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
  #24
Old 07-09-2015, 11:32 AM
MRK_KTL MRK_KTL is offline
Hi all. This is my first post and you might guess why I am posting here
Our little friend Laird just exploded, cracked open, in my 2½ old Artist Mix.
Does anyone know of the alternate component used by Avid to replace the CM3312R111R-10?
Cheers,
-Marco
  #25
Old 08-23-2018, 08:37 AM
Ben Wood Ben Wood is offline
Hi all,
I've got an Avid MC Control with the same issue, out of warranty.
Did anyone have any luck replacing the component?
If it is the CM3312R111R-10, the closest thing I can find in the UK is this...
https://www.mouser.co.uk/ProductDeta...252bJt5%252bw=
The issue is its a different size to the original.
I tried to match the max voltage (5A) and Impedance (110Ohms)
Many Thanks
Ben
  #26
Old 08-29-2018, 01:59 AM
Further investigation I found this replacement, rated up to 15A. Looks like its a similar size.
Only drawback its not available till 2019
https://www.mouser.co.uk/ProductDeta...MmGzrXC4BJeQ==
  #27
Old 01-04-2019, 05:03 PM
sirdemon sirdemon is offline
has anybody had luck finding a replacement part?
i have plenty of friends who could do this fix for me. my MCMix just died!
  #28
Old 01-06-2019, 02:42 PM
EddieJones's Avatar
https://www.mouser.com/ProductDetail...JcjqQnEg%3D%3D This is unsupported and you do this at your own risk.
  #29
Old 01-08-2019, 10:00 AM
thanks Eddie, have you used this part yourself?
  #30
Old 01-08-2019, 10:09 AM
EddieJones's Avatar
its used in the current Artist Mix units.
Artist Series and Power Mac G5 TGlee Artist Series 0 06-29-2013 06:42 AM
Artist and Control 24 users with experience. Comparisons please P,B,S Artist Series 3 05-05-2013 07:37 AM
So I wonder if PT11 will add for Artist users smfelton Artist Series 5 04-10-2013 10:57 AM
Unleash the power of our Artist Series, sysex, Mackie and MIDI RaToX Artist Series 0 03-31-2011 03:28 PM
Systems for NON-Power users? orchard69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-07-2008 05:47 PM
