Barracuda won\'t mount at startup on G4
Hi, sorry for this maybe newbie question, but I have the following problem:
I have a Seagate Barracuda SCSI disk (4.3 GB) that I used on my old 7300/180. I put it inside my G4 which has an Adaptec SCSI card (the 2906 or something like that, I think). The problem is that it doesn't mount at startup. I can mount it with SCSI Probe (although it gives me an error -60 or -56 in the log)and use it without problems. The disk SCSI ID is 2. I want the disk to be mounted at startup. I already tried the following: - used ID 0 and 2. - checked "mount at startup" on SCSI Probe. - formatted it in HFS and HFS+ - Update the driver with Drive Setup At one point one of the programs said "logical unit not supported" or something like that. Any help will be deeply appreciated. Thank you, ANDRES |
Re: Barracuda won\'t mount at startup on G4
Sounds like a problem I just had: cheetah formatted and mounted with FWB version 3.0, mounts on restart, no longer mounted on cold start. Problem was corrected by reformatting cheetah drive with FWB version 4.0, which is OS9-compatible; (3.0 officially not OS9-compatible). At least, we think that was the change responsible for the problem going away. Good luck.
JCC
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Seagate Barracuda vs. Barracuda XT? | reichman | Storage Subsystems | 0 | 04-12-2012 08:36 AM |
LCD mount? Where do I buy the low profile mount from demo? | sonicboost | VENUE Live Sound Systems | 6 | 08-28-2008 06:46 AM |
Barracuda 7200 or Barracuda ES? | JoyMODE101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-13-2006 01:40 PM |
seagate barracuda ata and 001 | slinky | Storage Subsystems | 1 | 12-24-1999 02:57 PM |
ST118273LW 18 gig Barracuda | gbours | Storage Subsystems | 3 | 06-15-1999 05:29 PM |
