Old 02-27-2011, 07:08 PM
~Murda Me~ ~Murda Me~ is offline
Default Why does pro tools 9 freeze up when i tried to record an instrument track?
I'm running windows 7 32 bit with i7 processor, 6 gb ram, and 2 hard drives with plenty space (self built). I keep getting a message it cannot auto save but it doesn't tell me why, nor does it explain how to turn it off (says what to turn off though i can't recall what it is at this time, but doesn't tell you where to find it). Also it just shuts down when i try to record an instrument track. i assume both problems are probably related. also when just playing an instrument the audio seems to sound really messed up at times, for instance a kick drum will almost sound like a horn or something similar, but if you hold the key down longer as the loops repeats it begins to sound correctly. i'm using a axiom pro 61 to play instruments btw and i have not tried recording audio yet. and yes this is a legal version i just haven't been able to get avid or the retailer on the phone
Old 02-27-2011, 08:45 PM
Default Re: Why does pro tools 9 freeze up when i tried to record an instrument track?
Help us Help You - READ THIS Before Posting!
Old 02-28-2011, 01:40 PM
don't know why your asking for a system report if this form will not let you post it saying it's too many characters
Old 02-28-2011, 01:43 PM
<<< Mainboard >>>
< Computer >
Manufacturer: Gigabyte
Model: EX58-UD5
< Computer Chassis >
Type: Desktop
Can be locked: No
< Mainboard >
Multi-Processor (MP) Support: No
Multi-Processing (MPS) Version:1.40
Model: EX58-UD5
Version: x.x
BIOS: 05/11/2009-X58-ICH10-7A89QG05C-00
Chipset: A89Q
< Computer Memory Controller >
Error Correction Capability: None
Number of Memory Slots: 6
Maximum Installable Memory: 6GB
Bank0/1 - A0: DIMM 2GB/2304 @ 400MHz
Bank2/3 - A1: Empty
Bank4/5 - A2: DIMM 2GB/2304 @ 400MHz
Bank6/7 - A3: Empty
Bank8/9 - A4: DIMM 2GB/2304 @ 400MHz
Bank10/11 - A5: Empty
< Chipset >
Model: Giga-Byte X58 I/O Hub
OEM Device Name: Intel X58 I/O Hub
Revision: B4
Bus: Intel CSI (Quick Path)
Front Side Bus Speed: 2x 2.43GHz (4.86GHz)
Maximum FSB Speed: 2x 3.2GHz (6.4GHz)
Width: 20-bit / 20-bit
HTT - Hyper-Threading Technolo:Yes
SLI Technology: Yes
Crossfire Technology: Yes
Maximum Bus Bandwidth: 19GB/s
Maximum Power: 24.10W
< Chipset 1 Hub Interface >
Type: Hub-Interface
Version: 2.00
Number of Ports: 4
In/Out Width: 16-bit
Full Duplex: Yes
Multiplier: 2x
< Chipset >
Model: Giga-Byte Core Desktop (Bloomfield) UnCore
OEM Device Name: Intel Core Desktop (Bloomfield) UnCore
Revision: A6
Version: 1.00
Maximum FSB Speed: 2x 17GHz (34GHz)
I/O Queue Depth: 64 request(s)
< Chipset 2 Hub Interface >
Type: Intel CSI (Quick Path)
Version: 1.00
In/Out Width: 20-bit / 20-bit
Full Duplex: No
Multiplier: 18x
I/O Queue Depth: 5 request(s)
< Logical/Chipset Memory Banks >
Bank 0: 2GB DIMM DDR3 8-8-8-20 4-28-9-5 1T
Bank 3: 2GB DIMM DDR3 8-8-8-20 4-28-9-5 1T
Bank 6: 2GB DIMM DDR3 8-8-8-20 4-28-9-5 1T
Maximum Installable Memory: 48GB
Supported Memory Types: DIMM DDR3 Scrubbing
Channels: 3
Memory Bus Speed: 2x 540MHz (1GHz)
Maximum Memory Speed: 2x 2GHz (4GHz)
Multiplier: 4x
Width: 64-bit
Integrated in Processor: Yes
Power Save Mode: No
Fixed Hole Present: No
Maximum Memory Bus Bandwidth: 25.31GB/s
< APIC 1 >
Model: Intel QPI I/O Hub I/O xAPIC Interrupt
Controller
Revision: B4
Version: 2.00
Multiplier: 1/2x
Maximum Interrupts: 24
IRQ Handler Engaged: Yes
Enhanced Support: Yes
< APIC 2 >
Model: Intel Trusted Execution Technology Registers
Revision: B4
Version: 2.00
Multiplier: 1/2x
< Memory Module >
Manufacturer: Corsair
Model: CM3X2G1600C8D
Serial Number: 004D4141
Type: 2GB DIMM DDR3
Technology: 8x(1024Mx8)
Speed: PC3-12800U DDR3-1600
Standard Timings: 9-9-9-24 5-34-10-5
Version: 1.00
Timing @ 444MHz: 6-6-6-16 3-23-7-3
Timing @ 593MHz: 8-8-8-21 4-30-9-4
Timing @ 667MHz: 9-9-9-24 5-34-10-5
Enhanced Performance Profiles: Yes
Profile @ 800MHz: Optimal: 8-8-8-24 6-41-12-6 2T 1.6V
< Memory Module >
Serial Number: 004C5A41
Type: 2GB DIMM DDR3
Version: 1.00
< Memory Module >
Type: 2GB DIMM DDR3
Version: 1.00
< Sensors 1 >
Model: ITE IT8720F LPC
Version: 8.00
Mainboard Specific Support: No
< Sensors 2 >
Model: Intel Core CPU [P0, C4, T100]
Version: 26.05
< Sensors 3 >
Model: ITE ITE820X SMB
Version: 0.18
< Temperature Sensor(s) >
Board Temperature: 34.00°C
CPU 1 Temperature: 54.00°C
CPU 2/Aux Temperature: 41.00°C
< Cooling Device(s) >
Auto Fan Speed Control: No
System Fan 1: 111rpm
< Voltage Sensor(s) >
CPU 1 DC Line: 0.94V
CPU 2/Aux DC Line: 1.52V
+3.3V DC Line: 0.13V
+5V DC Line: 5.00V
+12V DC Line: 1.62V
-12V DC Line: -16.64V
-5V DC Line: -8.37V
Standby DC Line: 3.58V
Battery DC Line: 3.26V
< System Bus(es) on Hub 1 >
Version: 2.30
System Bus 0: PCI
System Bus 1: PCIe 2.00 x4 2.5Gbps
System Bus 2: PCIe 2.00 x16 5Gbps
System Bus 3: PCIe 2.00 5Gbps
System Bus 4: PCIe 2.00 x16 2.5Gbps
System Bus 5: PCIe 2.00 2.5Gbps
System Bus 6: PCIe 1.00 x1 2.5Gbps
System Bus 7: PCIe 1.00 x1 2.5Gbps
System Bus 8: PCIe 1.00 x1 2.5Gbps
System Bus 9: PCIe 1.00 x1 2.5Gbps
System Bus 10: PCI66
System Bus 255: PCI
< LPC Hub Controller 1 >
Model: Giga-Byte LPC Interface Controller
OEM Device Name: Intel LPC Interface Controller
Revision: A1
ACPI Power Management Enabled: Yes
Advanced TCO Mode Support: Yes
Advanced TCO Mode Enabled: No
High Precision Timer Enabled: Yes
Number of Precision Timers: 4
System Timer: 14.32MHz
Delayed Transaction Enabled: Yes
< LPC Legacy Controller 1 >
Type: ITE IT8720F
Version: 0.20
Number of Enabled Devices: 4
< Disk Controller >
Model: Giga-Byte 4 port SATA IDE Controller
OEM Device Name: Intel 4 port SATA IDE Controller
Interface: SATA
Revision: A1
Maximum SATA Mode: G2 / SATA300
RAID Support: Yes
RAID Enabled: No
Channels: 4
In Use Channels: 2
Port: G2 / SATA300
Port: G2 / SATA300
< Disk Controller >
Model: Giga-Byte 2 port SATA IDE Controller
OEM Device Name: Intel 2 port SATA IDE Controller
Interface: SATA
Revision: A1
RAID Support: Yes
RAID Enabled: No
Channels: 2
In Use Channels: 1
Port: G2 / SATA300
< Disk Controller >
Model: Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID
Controller
OEM Device Name: Jmicron JMB36X PCIE-to-SATAII/IDE RAID
Controller
Interface: ATA
Revision: A3
Channels: 4
< Audio Device >
Model: Giga-Byte HD Audio Controller
OEM Device Name: Intel HD Audio Controller
Revision: A1
Type: HD (High-Definition) Audio
Version: 1.00
Number of In / Out / Bi-Direct:4 / 4 / 0
Number of Serial Data Streams: 1
< Audio Device >
Model: ATI (AMD) EG JUNIPER XT Audio Device [Radeon
HD 5700 Series]
OEM Device Name: ATI (AMD) EG JUNIPER XT Audio Device [Radeon
HD 5700 Series]
Revision: A1
Version: 1.00
Number of In / Out / Bi-Direct:0 / 1 / 0
< USB Controller 1 >
Model: Giga-Byte USB UHCI Controller #4
OEM Device Name: Intel USB UHCI Controller #4
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
Supported Speed(s): Low (1.5Mbps) Full-Length (12Mbps)
Legacy Emulation Enabled: No
< USB Controller 2 >
Model: Giga-Byte USB UHCI Controller #5
OEM Device Name: Intel USB UHCI Controller #5
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 3 >
Model: Giga-Byte USB UHCI Controller #6
OEM Device Name: Intel USB UHCI Controller #6
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 4 >
Model: Giga-Byte USB EHCI Controller #2
OEM Device Name: Intel USB EHCI Controller #2
Revision: A1
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 6
Companion Controllers: 3
Supported Speed(s): Low (1.5Mbps) Full-Length (12Mbps) High
(480Mbps)
Addressing Support: 64-bit
< USB Controller 5 >
Model: Giga-Byte USB UHCI Controller #1
OEM Device Name: Intel USB UHCI Controller #1
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 6 >
Model: Giga-Byte USB UHCI Controller #2
OEM Device Name: Intel USB UHCI Controller #2
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 7 >
Model: Giga-Byte USB UHCI Controller #3
OEM Device Name: Intel USB UHCI Controller #3
Revision: A1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 8 >
Model: Giga-Byte USB EHCI Controller #1
OEM Device Name: Intel USB EHCI Controller #1
Revision: A1
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 6
(480Mbps)
< FireWire/1394 Controller 1 >
Model: Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-
layer Controller
OEM Device Name: TI TSB43AB23 1394a-2000 OHCI PHY/link-layer
Controller
Revision: A1
Version: 1.10
Interface: OHCI
Speed: 400MHz
< SMBus/i2c Controller 1 >
Model: Intel ICH SMBus
Specification: 2.00
Advanced TCO Mode Enabled: Yes
Slave Device Enabled: Yes
PEC Support: Yes
Speed: 100kHz
< Expansion Slot(s) >
PCI: PCI 32-bit +5V +3.3V PME i2c/SMBus Full-
Length Available
PCI (1h): PCI 32-bit +5V +3.3V PME i2c/SMBus Full-
Length Available
< Port Connector(s) >
PRIMARY IDE: ATA
FDD: 8251 FIFO / Floppy Disk
Keyboard: Keyboard / PS/2
PS/2 Mouse - No Detected: Mouse / PS/2 / PS/2
USB: USB / USB
USB: USB / USB
< Performance Enhancing Tips >
Notice 224: SMBIOS/DMI information may be inaccurate.
Tip 2511: Some memory slots are free so the memory can
be easily upgraded.
Warning 2519: One of the system fans has failed or is
spinning too slowly.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
Old 02-28-2011, 02:42 PM
Please spend a half hour reading other posts so you can see what the usual Sandra report looks like. This is not what I was looking for. Here's a perfect example: http://duc.avid.com/showthread.php?t=295722
Old 02-28-2011, 04:01 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
I removed irrelevant posts.
The Help Us Help You states specifically how to create a proper Sandra report:
After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Avid Audio Tech Support
Support FAQ
Old 03-01-2011, 09:00 AM
SiSoftware Sandra
Computer
Model : Gigabyte EX58-UD5
Workgroup : WORKGROUP
Host Name : Home-PC
User : Home
Processor
Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Speed : 2.83GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : Gigabyte EX58-UD5
BIOS : Award (Phoenix) F7 05/11/2009
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.43GHz (4.86GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Total Memory : 6GB DIMM DDR3
Channels : 3
Memory Bus Speed : 2x 540MHz (1GHz)
Memory Module(s)
Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : ATI Radeon HD 5700 Series (800 SM5.0 850MHz, 1GB DDR5 4.8GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : ATI Radeon HD 5700 Series (800SP 850MHz, 1GB DDR5 4.8GHz 128-bit)
STREAM Processor : ATI Radeon HD 5700 Series (800SP 10C 850MHz, 1GB DDR5 4.8GHz 128-bit)
Storage Devices
WDC WD6401AALS-00L3B2 (640.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 596GB (C:)
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm) : 1TB (E:)
PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Sessions (E:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
Hard Disk (C:) : 596GB (NTFS) @ WDC WD6401AALS-00L3B2 (640.1GB, SATA300, 3.5", 7200rpm, 32MB Cache)
3.5" 1.44MB (A:) : N/A
Optical Drive (D:) : N/A @ PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : ATI (AMD) EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Amyuni Document Converter 2.51 (1200x1200, Parallel, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Fax Lexmark 5600-6600 Series Printer (200x200, Colour)
Network Services
Network Adapter : Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps)
Network Adapter : Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x86
Windows Experience Index
Current System : 5.9
Old 03-01-2011, 10:41 AM
Nothing on the Sandra is raising a flag for me. Could it be a driver issue? Or maybe some other software causing the issue? I see that Avid is now recommending nVidia graphics, but I don't see how that would be the cause(so I am not suggesting a new video card). I record instrument tracks on my rig(quite similar to yours) all the time with various midi controllers(Motif es8, Ensoniq keyboard and Roland TD10 kit). Maybe its a midi driver issue. What VI are you using when the freeze happens? Are you inserting it in Slot A(you should)? Not sure it would help, but you should try disabling the network ports to see if it helps.
Old 03-01-2011, 10:52 AM
mykhal c's Avatar
mykhal c mykhal c is offline
unless you have the /3gb switch set in your BCD store then you are only usin' 2gb of ram. my suggestion is upgrade to W7 x64. you'll be limited to 4gb per application then. and if that's not an option then use the /3gb switch. your INSTs are chokin' on the amount of ram.
EDIT: also change the number of procs in the RTAS engine...7 procs or less @99% if you are usin' hyperthreading....set to 3 if HT is not turned on.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 03-01-2011, 12:46 PM
Originally Posted by albee1952 View Post
I see that Avid is now recommending nVidia graphics, but I don't see how that would be the cause(so I am not suggesting a new video card). i spoke with them about this and they said it wasn't an issue
What VI are you using when the freeze happens? it happens on all virtual instruments and all i have are the ones that came with pro tools
Are you inserting it in Slot A(you should)? don't know what slot A means sorry
Can't record instrument track 2 with MIDI... cf_mono Windows 1 04-06-2013 08:25 PM
Instrument track will record, but no notes appear? JohnnyStalde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-29-2011 01:44 AM
Instrument track with Eleven selected will not record Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-08-2010 11:28 PM
Instrument Track won't record MIDI WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-19-2009 12:20 AM
MIDI to Instrument track record DonaldM MIDI 5 05-07-2008 03:57 PM
