Old 08-29-2005, 03:04 PM
maxithev maxithev is offline
Default Control room level button works only on one ch
hello, I'm using my C8 for a little while now, with no problem, but I still haven't found why the control room volume level button doesn't shut down both speakers, but only one of the two... and the remaining still sings of course. Which means that I actually control not much in the room...
Anyone with the same problem ? Have I miss something in installing ?
thanks
maxithev
PT12 on windows10, MS Surface Pro ;
PT11 on OSX10.11.6, MacPro
Old 08-31-2005, 10:17 AM
DigiTechSupt's Avatar
Default Re: Control room level button works only on one ch
Are you still having problems with this? Are you saying that you turn down the volume, but it only controls 1 speaker?
If so, you should contact Digidesign Technical Support for further troubleshooting.
650.731.6100
Avid Audio Tech Support
Support FAQ
Old 08-31-2005, 11:00 AM
thank you for replying so fast.
Yes, that's exactly what happens.
you mean Digi tech support in France... ? I'll find the phone number.
maxithev
Old 11-01-2005, 04:34 PM
Tom Mix Tom Mix is offline
Hi Maxithev,
I'd be very interested to find out what Digi had to say about this Control Room volume problem. I have the same. It's mentioned a few times (with slight variations) on the DUC without ever a mention of a solution. Hopefully you've had better luck with the Digi tech support # you were given. ( 20 mins.on hold is about my limit w/a cell phone - but I'll keep trying ) Somehow I missed your Post when I did a search a few weeks ago or I would have asked you sooner. Now my hopes are up again. I'd really like to use that feature.
All the best, Tom Mix
AZ Shortcuts Button No Longer Works schumann1000 Pro Tools 11 2 11-14-2013 06:59 PM
Anyway to get visual feedback for the Monitor/Control Room level on the Artist Contro Focuret Artist Series 0 11-19-2012 11:46 AM
Artist MIX with control room level ! claes1965 Artist Series 1 01-28-2012 09:16 AM
Control Room Level 3001 Studios Artist Series 7 02-18-2011 01:22 PM
ProControl- Control Room Section NO longer works after Upgrades adrielw Pro Tools TDM Systems (Mac) 8 06-28-2009 11:29 PM
