Using Pro Tools Artist with an X32
Hi all,
Trying to use ProTools Artist with an X32 using 32 outputs out of ProTools and play back tracks through the X32. I am able to set the X32 card to do 32in/32out and PT sees all 32 I/O. I've already set the outputs for all channels correctly (channel 1, output 1, so on), but am only getting channels 1-16 to send back to the X32. I see that PT Artist only supports 16 simultaneous inputs, but doesn't mention anything about outputs. I assume its possible that they include outputs with this 16 channel limit, but it doesn't explicitly state that anywhere that I've seen. Has anyone else run into a similar issue with this? Thanks! Daniel T |
Re: Using Pro Tools Artist with an X32
It’s typically mirrored. 16 output limit would be correct.
If you want to utilise all 32 outputs, you’ll need Pro Tools Studio which gives you 64 I/O. Sent from my iPhone using Tapatalk |
Correct^^^ Sweetwater's info does refer to 16 IO for Artist.
Cannot setup Artist Control and Artist Mix to work at the same time | elchuliver | Artist Series | 1 | 06-12-2022 07:20 PM |
EuControl 20.6.1.3 not working on Mojave with Artist Control and Artist Mix | SvenIsak | Avid S1, S3, Dock and Control App | 3 | 10-09-2020 12:59 AM |
Can I change Eucon Layouts with an Artist Mix or Artist Transport? | amathie | Artist Series | 10 | 09-21-2017 07:29 PM |
2 avid artist mixes and one artist control V2 for sale | Brandonx1 | Buy & Sell | 2 | 03-21-2016 09:55 PM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
