Low analog line input on 192 i/o inputs (AD)
Hello All,
Just bought a 192 i/o with an AD Expansion interface. Installation and software setup of HD2 went smoothly. Bought also 3 Digisnakes (DB25 to 8 TRS Balanced)... so everything according to the book. Oh yes, I am using a Power Mac G5 Quad. Problem: the 16 AD inputs are very low in line input level !!! Even with synthesizers at maximum volume, I can't reach -20 db ! What I already tried: 1) switching the DB25 from +4dBu to -10dBV interface -> worse 2) removed patchbay (Neutrik NYS-SPP-L) and connected an outboard synthesizer directly with non balanced cabling -> same result 3) reconfigured analog output options (trim settings) from A to B for each line output -> better, but still not sufficient line input 4) checked calibration mode: all OK 5) changed the input trims below the two DB25 connectors ... not enough gain (calibrated back to original settings) I am out of ideas here. I migrated from a PT24 Mix Plus with 882/20 interfaces and never saw this problem. Thanks for all other ideas !!! Dirk |
Re: Low analog line input on 192 i/o inputs (AD)
Two things.
Typically, synthesizer outputs vary in nature and level. The vast majority feature unbalanced outs referenced to -10. The latter kind just isn’t designed to comfortably drive a balanced/+4 input. Use a pre-amp with “direct” input to feed the 192, or a separate DI box feeding a preamp. Also, just to eliminate variables, are you sure that your Digisnakes are the DB25-TRS kind? Digisnakes come in two 1/4" varieties. The ones you want are colored orange. Digi also makes a snake with TS terminations (colored <font color="#666666">grey) which have built-in resistors, designed to attenuate +4 signals from a 192 output fed to external gear with -10 inputs. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Hi Andre,
Thanks for your answer . I am using the Digisnake Orange TRS Balanced cable like you mentioned. So what you are suggesting is that I MUST connect the snake to the DB25 -10dbu connector to drive up the input level ? Strange, because I've never seen this issue with the 882/20. I rather don't want to use a separate preamp for my outboard gear. Still desperately seeking for a solution... Dirk |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
Mic/Line and Line inputs on Mbox2 Pro | DAT11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2007 08:06 PM |
Computer Noise From Mbox 2 Analog Inputs (Line/DI) | Ayotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-27-2006 01:02 PM |
Mbox-setting input levels w line inputs or s/pdif | peccatte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-22-2003 09:20 PM |
Digi 001's line level inputs 3-8. Control input? | dcarlson247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-26-2001 02:04 PM |
