Old 05-27-2005, 08:29 AM
K.I. K.I. is offline
Default 6.92 sessions are made a template
When as many as 6.92 sessions are made a template, it is copied.
It doesn't improve it from 6.9.
Old 05-27-2005, 10:21 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: 6.92 sessions are made a template
read the 'read me' included in the installer. I think I remember seeing that mentioned in it.
Also ... this seems not to be a digidesign 'issue' but a OS issue. Try it with other app's ... like word or whatever ... I think you might see similar behaviour.
the workaround is to open the template from inside the application. It will not create a duplicate and will prompt the edit stationary or create new session dialog.
Still ... you have to check disk allocation after creating a new session , especially if your adressing another drive then the template.
All in all, I've changed my 'template' ways alltogether. I create a new empty session and import session data from the template. A workaround I know but the less hassle full one imvho.
Chris Lambrechts
Applications Specialist- Live Sound
Template for projects from same recording sessions? aidanm Pro Tools M-Powered (Mac) 3 10-01-2007 01:09 AM
Can I open sessions made in HD, LE and M-powered? fucdemas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-18-2007 06:30 PM
a session made from a template contains automation MixerGuy Pro Tools TDM Systems (Mac) 5 08-16-2006 12:08 AM
I made a template for Yamaha DTXplorer and BFD GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-27-2006 10:16 PM
how do you make template sessions? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 05-20-2002 01:42 PM
