Old 10-22-2017, 07:33 PM
Zak7 Zak7 is offline
Default VCAs Rec Button ?? Stems using VCAs
Hi, can you please guys explain to me what is the use of the Rec Button on a VCA track?
I heard some people use VCAs to create multiple stems in 1 pass recording after a mix.
PLease, can you elaborate this Method?
Many Thanks!
Old 10-23-2017, 03:27 PM
Default Re: VCAs Rec Button ?? Stems using VCAs
anyone??
Old 10-23-2017, 03:35 PM
priorytools priorytools is offline
Unlike VCAs on traditional analog consoles, VCA Master tracks in Pro Tools directly affect their slave tracks, so that the controls on each slave track always show their actual values:
• The output level of each slave track is indicated by the position of its fader.
• The solo, mute, record enable, and TrackInput status of each slave track are indicated by the corresponding controls on the track.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 12.5 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.9.1 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 10-23-2017, 08:01 PM
albee1952 albee1952 is online now
This is a place where the VCA drops the ball. Assuming you have, let's say, 8 drum tracks that are part of a group and connected to a VCA track. You would THINK that hitting the Record button on the VCA would enable all the drum tracks, but at the moment, that does NOT work(as I think it should). However, once you enable Record on the 8 drum tracks, from that moment on, the VCA Record button WILL toggle record on the 8 drum tracks(until you close the session and come back, at which point, you are back to the beginning)
Now, re the term "STEMS", that would be more appropriate to using AUX tracks and routing groups of tracks(like all the drums, or all the BGV's) VCA's are really just a way to control the overall level of a group of tracks(a "stem" is a recording of a group of tracks into their own "submix", which is also referred to as a "stem")
Old 10-25-2017, 06:59 AM
JFreak's Avatar
JFreak JFreak is offline
Also worth mentioning that "for some ears" creating submixes deteriorates sound, so mixing with stems isnt a holy grail. But opinions do vary...
Janne
Old 10-25-2017, 07:53 PM
cwsand's Avatar
cwsand cwsand is offline
Curious - what's the thinking behind this - especially in the digital realm?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.10
Old 10-26-2017, 08:51 AM
JFreak's Avatar
Some say extra summing (auxes/stems) makes the end result different and not in a good way. They say PT mixer only has real stereo image when all tracks go directly to output (only one summing).
I don't share that view but have heard it many times.
Janne
VCAs Spill bug bucha Avid S6 7 09-19-2017 09:00 AM
Explain me PT HD VCAs please? acmost macOS 15 09-03-2015 11:55 AM
Busses and VCAs Reckless Erik Post - Surround - Video 7 01-27-2011 03:03 AM
VCAs in M Powered 8 Dub till ya drop Pro Tools M-Powered (Win) 2 10-05-2010 02:55 AM
What's on your VCAs? mtung ICON & C|24 8 08-17-2009 01:52 AM
