Old 07-27-2000, 01:42 AM
Neil Ward Neil Ward is offline
Default The Apple cd player & digi001 outputs issue.......
All,
I have just encountered my first snag since updating to 5.0.1 The damn cd Player doesn't play, it just sits there doing nuttin', when you go the the sound control panel and change the output back to internal it works (through the ****ty internal speaker ) .... not what we need here, is it poeple?!?!?!
I've just finished searching the DUC for a fix and I see plenty of posts with the exact same issue, but no fix.... I'm gonna try the Retro CD thing tonight, but that's not my major gripe....
Audio extraction from CD's is now a pain, the toast audio extractor will read cd's, and even extract audio, but the damn cd won't play So you can't audition clips before extracting them, at least not without changing the output source all the time...
I'm sure others must have this problem too? Damn irritating, come on Digi where's the fix already!!!!!
//NW
Old 07-27-2000, 02:52 AM
sandman sandman is offline
Default Re: The Apple cd player & digi001 outputs issue.......
exasctly man !
i didnt want to post this problem not to sound like DR ruth
but its sure irritating as hell ah
check this out>>>>
before the latest update the apple cd was working good (going out from the 001 outputs !!
now i can see two (2) digi symbols in the sound folder
nothing work thru
give them prowork >it will work , give them simple work>>were in truble
sandman
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow!
Old 07-27-2000, 03:02 AM
Yeah, this sux alright!!!
I have 9.0.4 and the mulitmedia upgrade, I've tried disabling the direct i/o extension, cause I believe it is no longer reuired with 5.0.1le and still I don't get zip!
Does anyone have this working, without Retro CD that is?
Old 07-27-2000, 10:50 AM
DigiTechSupt's Avatar
Neil Ward
9.x users should update to 9.0.4 and QT 4.1.2
plus all software upgrades from the apple site. Using 9.0.4 and PT 5.0.1 you should use the new digidesign control panel and disable or remove the digidesign output drivers
from the extention set. The sound control
panel output set to digidesign. 8.6 users
should use the digidesign output driver
and not use the digidesign control panel.
Following the above, we were able to get the apple CD working on OS 9.0.4.
MJ
Digidesign tech Support
Avid Audio Tech Support
Support FAQ
Old 07-27-2000, 11:24 AM
MJ
Thanks for the response
I have done all you described except QT 4.1.2 (I have QT4.1), do you have a link to the download?
Thanks for listening, The DUC rulz
//NW
Old 07-27-2000, 02:12 PM
hmmmm,......
I found the QT update, downloaded and installed it, and things got hairy
I now have NO sound when the 001 is selected as the sound out, before I at least had the system sounds. To make matters more intersting I cant get sound out quicktime documents, I get an unexpected error -2804.
Info
Macos 9.0.4 +Multimedia update
PTLE 5.0.1
Digidesign Direct I/O disabled in extensions manager
Digidesign Control panel enabled
Digi001 selected in sound control panel
Any help would be greatly appreciated.
thanks
Neil
[This message has been edited by Neil Ward (edited July 27, 2000).]
Old 07-27-2000, 02:53 PM
I think the Direct I/O extension is a necessary component for this to happen. Enable it in your current extension set (along with all other Digi specific extensions), restart and try it again.
Brent
Support FAQ
Old 07-27-2000, 10:28 PM
thumbolt68 thumbolt68 is offline
i updated to LE5.0.1, OS 9.0.4, updated to QT4.1.2 and my extensions seem correct but my apple cd player wont play. also 001 wont open up. i get a window saying "digidesign hardware is either not installed or is in use by another program. what the bejeezus is going on here?
Old 07-28-2000, 12:19 AM
Hi Brent
Thanks for the input, I will give it a shot this evening....
//NW
Old 07-30-2000, 01:26 AM
0dbfs 0dbfs is offline
I couldn't get any third pary audio to play through my digi001 without crashing until I updated the Direct I/O extension to v5.0.1a. v5.0.1 would freeze my mac requiring a restart after playing a couple minutes of audio.
Apple DVD player thru Digi002 HW? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-05-2008 02:05 PM
5.1 to the ICON from Apple DVD player? sburrows ICON & C|24 4 02-09-2006 02:16 PM
Apple DVD player not working w/ PT LE 5.0.1 Ryan Owens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 10-11-2002 05:54 AM
apple dvd player does not work w/ 5.01? thehypercube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-02-2000 02:13 PM
Fix for Apple CD player!!! nuke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-12-2000 03:51 AM
