Assign Fader layouts to soft keys...?
Hi-
Since the preset "Fader layout select", assigned to the function keys on the left, does not seem to work in PT10 or Logic X, i am wondering of i can assign them manually as soft keys to whatever soft keys i want. Anybody knows whether "Fader layout select" Is a command that can be used? Thanks! |
Re: Assign Fader layouts to soft keys...?
Yes, you can recall layouts using any of the programmable soft keys.
How do you access the "layout recall" commands when programming in Soft Keys? |
In the Soft Key Command Editor page of Eucontrol, select 'MC' in the Command drop down menu. This will add a layout recall command to your selected soft key.
Can I assign a plugin to a soft keys?!?!? | fenders74 | Artist Series | 2 | 06-16-2014 04:41 AM |
Assign Pause & key command to soft keys? | mikekiraly1 | Artist Series | 2 | 02-03-2012 10:29 AM |
Recalling fader layouts on MC Mix only? | Schottlandru | Artist Series | 13 | 10-21-2011 01:08 AM |
Can you break up samples and assign to Keys? | achapman | Pro Tools M-Powered (Mac) | 1 | 01-14-2011 01:43 PM |
Easier way to assign layouts in EuControl | postprosound | Artist Series | 3 | 01-05-2011 02:02 PM |
