Strange disk permission crash with Ozone 5
Installed Ozone 5 advanced demo! and PT would crash opening a session. tried 3-4 times then removed the ozone plugins and all was fine again. repaired disk permissions and was able to load a session with ozone in the plugins folder. worked fine till the next boot of the mac and the same issue, just crash until i removed the plugins or repaired disk permissions again. When i repair disk permissions i get a whole load of messages about "Java" And one message about SUID file system/library/core services/ remote management/ ARDAgent.app "has not been repaired and will not be repaired" Any ideas? Chris
Re: Strange disk permission crash with Ozone 5
ARD is Apple Remote Desktop and this kbase seems to indicate that error is not a problem and can be safely ignored...so you may have to look elsewhere for the culprit:
https://support.apple.com/kb/TS1448?viewlocale=en_US |
You could try using the download of the OS version updater for the OS version you have installed and run it - it may fix the problem.
Thanks keith, I tried to update Java, although the website said 10.6.4 or above, when i went to install it said it needed 10.6.8. I'm on 10.6.7 so think i'll update to 10.6.8 using the combo updater and effectively this might do what you suggest. Quite bizarre, never had anything quite like this before. chris
Chris I ran the demo of Ozone 5 Advanced on 10.6.8 with no problems.
When you do get it running please check out the meter response of O5 when using Audiosuite. So slow and jumpy that it's unusable. I sent them a report.
HD Accel 2, Magma PER64-I Mac Pro 2x3.2 Quad Core/OSX 10.6.8/VEPro/PT9.03 http://philbuckle.com/ |
Just an update. Updated to 10.6.8 from 10.6.7 using the combo updater then updated to the latest Java. Now when i try to load a session with ozone 5 advanced demo, it gets to loading the mix bus then the auth screen for ozone appears and i select to continue and everything just stops loading and PT becomes unresponsive and i have to force quit. Tried repairing disk permission but no go. had to remove ozone 5 from the plugs folder to load the session. Bizarre, never seen anything like this one before. No biggie as i only use the dithering but wanted to test against O4 Chris
That is too bad you cannot get it working because I think ozone 5 is pretty good.
B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
Have you tried reinstalling Ozone? Or testing from a new admin account? Sometimes doing that will allow it to work in your original account.
Yes i'll try that. Izotope sent me a new build yesterday which helps a bit as i doesn't crash, but it still stops at the auth screen for Ozone, although i have 5 days remaining on the demo i press continue and everything just stop responding. Repair disk permissions and it works till the next computer boot. Chris
Did you ever resolve this? I'm trying to run the Ozone5 demo and it's crashing every time I try to close a session or remove the plugin from an insert. |
9.0.6 crash with Ozone 4...? | leononeill | macOS | 5 | 12-30-2011 08:30 AM |
When updating to 8.03 ask for strange permission | Energie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-22-2009 09:57 PM |
Pro Tools 8 & Disk Permission errors | edb200 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-25-2009 08:04 PM |
Disk Permission problem | ndlsd | Pro Tools TDM Systems (Mac) | 2 | 04-20-2006 04:03 PM |
Strange Disk Crash Any Ideas Anyone? | John Andrew | Pro Tools TDM Systems (Mac) | 0 | 09-16-2002 02:05 AM |
