Old 03-12-2004, 11:51 AM
Fritz Fritz is offline
Default 9 pin Machine Control ports on USD or SYNC
G4 Ti, Magma 2 slot with Mix cards and USD. DA98. Both locked to black burst.
Is 9 pin possible w/6.2.3 or is it still only the Keyspan device?
Would it be easier or better with a SYNC?
In MC set-up. the only port that shows available is modem and Digiserial is grayed out. I couldn't get the modem to go away for nothing.
Even with the MC cable, (from digiserial on Core to 98) TC was counting a little jagged in PT.
"Do not fear mistakes. There are none."
Miles Davis
Old 03-13-2004, 07:51 AM
Default Re: 9 pin Machine Control ports on USD or SYNC
anyone? I know you're out there. I can hear ya sighing
Miles Davis
Old 03-13-2004, 10:04 AM
sheldon013 sheldon013 is offline
Hi Fritz,
I spoke to the digi guys about this a while back, they said the digiserial ports on the back of the USD have
never worked and will never work. The digiserial ports on the SYNC IO though do work for RS422 control.
I would get your local digi guy to demostrate it before you buy though just in case.
Hope this helps.
Alan.
Old 03-13-2004, 10:20 AM
The ports on the SYNC I/O do work, but if you use a V1 or any other non-linear device, you'll need to use the Keyspan USA-28x USB<-->Serial adapter to get acceptable performance (contrary to what Digidesign's documentation says).
Old 03-14-2004, 06:21 AM
thanks Alan. I have access to a SYNC so I'll give it a go.
Miles Davis
Old 03-14-2004, 06:23 AM
thanks CT. the only non-lin I use is imported QT movies. I'm looking to be knowledgeable for VTRs and the like.
Miles Davis
Old 03-17-2004, 11:56 AM
I have a SYNC loop connected to a 888/24 and a Magma 2 slot with a Mix Core and Farm. PT 6.23 OSX.3.2.
The DigiSerial port on the Core is connected to the SYNC. When I open a new session and try to set-up MC, Sync I/O is not seen. I have black burst going to both the SYNC and the DA98. The 9 pin from the Sync p1 to the 98/422. The SYNC sees the incoming code and video ref. The 888/24 says SYNC mode on the fp. I tried a restart, NC.
Will the Sync I/O not work with Mix cards in X? Or perhaps the 888/24?
Will the HD I/O recognise the Mix Cards or do I need to do a card swap?
Is MC just not happening in X w/o the Keyspan?
Then I stepped back to 5.3.1 OS9.2.2 on a Mirror door. Connected DA98 9 pin to Sync p1. Looped the Sync to the HD I/O, etc. Syncs up fine and fast. Though for some reason Machine Track Arm doesn't work.
Miles Davis
Old 03-18-2004, 04:43 PM
Tiago Silva Tiago Silva is offline
Test case:
G4/500 AGP 10.3.2 PT6.3.2
192 I/O + SYNC connected to HD core through DigiSerial
9pin connected to one of the SYNC's ports
In this configuration, Machine Control locks 85% of prerolls with positional reference given by LTC, and almost never works with serial timecode. Machine Track Arm works, with the usual caveats; thank gawd someone had the bright idea to include a track arm profile editor...
Of course, a Keyspan adapter connected to a USB card locks 99% of times with LTC and about 95% with serial...
Oh, and forget about the gPort... It hangs the whole system... Had to reboot with the Power button... Bad, bad idea...
A job's not done until it's ready, or the producer is breaking down the studio's door...
Old 03-18-2004, 07:11 PM
I'll have to take a closer look at the Track arm editor and give it a try with the Keyspan.
Thanks.
Miles Davis
Old 03-18-2004, 08:00 PM
The SYNC I/O does work with MIX cards and 888/24s in OS X. I've got three (soon to be four) working.
MachineControl works with the SYNC I/O in OS X, though if you are using non-linear decks, get a Keyspan. Trust me.
HD I/O recognizing MIX cards? You lost me there.
What is not seeing the SYNC I/O in your session?
I thought v6.2.3 and Panther for MIX weren't qualified yet. Did I miss something?
HTML code is On
Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync audiomark Post - Surround - Video 5 02-14-2013 03:09 PM
Machine Control COM Ports: Sync I/O vs CPU Tom Smith Post - Surround - Video 5 08-19-2008 02:10 PM
machine control and sync louisenslinproduce Pro Tools TDM Systems (Mac) 4 02-27-2007 10:51 PM
USD+Machine Control+Cannot Sync to LTC babyseal Pro Tools TDM Systems (Mac) 0 06-26-2003 02:11 PM
Sync & Machine Control blanos212 Pro Tools TDM Systems (Mac) 0 02-25-2002 03:03 PM
