Old 04-23-2019, 07:28 AM
Sndnerd Sndnerd is offline
Default AJA LHi picture drift
I just upgraded to Ultimate 2018.12 and my AJA LHi picture drifts over long uninterrupted playbacks - around 20mins it becomes noticeable. It goes out of sync, but jumps to correct itself. Anyone encountered this?
Old 04-23-2019, 10:48 AM
quadraphonics quadraphonics is offline
Default Re: AJA LHi picture drift
I see something similar in 12.8.3 and 2018.10 with a different AJA interface.
How are you resolving video sync?
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 04-23-2019, 09:15 PM
It's locked to AJA GEN10. Stopping and starting playback resolves the drift right away, but for long-form client playbacks it's not ideal stopping and starting.
Old 04-24-2019, 04:18 AM
And PT is locked to the same clock via a Sync HD?
F.
PTHDn 2019.10 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 04-24-2019, 07:52 AM
F.
Correct, sync is locked.
Old 04-24-2019, 08:02 AM
Hm, odd. Can't confirm as I'm on a different card (see below) but I'm not getting this with my setup so could be AJA (driver, settings?) related. I've had all sorts of odd strobing effects and weird almost like slomo picture with AJA cards in the past where you had to restart the system to get it back to normal. Like once or twice a day. But this was with Satellite setups. So might be different.
One thing: The BM card has to receive the same format clock as the video in the session to properly lock. Not sure if that's the same with AJA. So if your QT is 1080P 24.00fps the Trilevel sync signal has to be the same. The BM settings will indicate if the card is locking.
Old 04-24-2019, 11:28 AM
Interesting. I am noticing the Gen10 has only 2 formats - 50 and 59.94. PT is at 23.98 so no speed difference for 59.94/29.97 but still I wonder if it might have something to do with it.
Old 04-24-2019, 01:38 PM
The Gen 10 does 23.98 just fine. See the DIP switch matrix on page 6:
https://www.aja.com/pdf/support/manu...0_pn101664.pdf
It can do any of these:
525i, 625i
720p 23.98/24/25/29.97/30/50/59.94/60
1080i 50/59.94/60
1080psF 23.98/24/25/29.97/30
1080p 23.98/24/25/29.97/30
You might have it set to the wrong clock?
F.
Old 04-24-2019, 01:52 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
We have /ever had no issues with Aja LHi at all.
See my specs for details.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2019.10 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 04-24-2019, 01:54 PM
525i, 625i
1080i 50/59.94/60
F.
Wow, thanks. I'm now locked at 1080p 23.98, here's hoping that does it.
HTML code is On
IAC bus drift Dr Fletch macOS 1 12-08-2017 09:50 AM
LA Drift... Pred80r Pro Tools TDM Systems (Mac) 0 03-30-2011 11:08 AM
Audio Drift issue synching music to picture daisytone Post - Surround - Video 4 06-12-2010 09:50 PM
PT 7.4 Video drift soundfx Post - Surround - Video 9 11-29-2007 11:47 AM
Does quicktime drift? Locash Post - Surround - Video 1 02-16-2004 11:43 AM
