Old 06-11-2014, 12:28 PM
SweetSoulSound SweetSoulSound is offline
Default Send A-E bus assignments change colour
Hi, Everyone-
This is really a novice's question, but we've all got to start somewhere, right?
I've sent up my signal routing for my headphone mixes. When I record-enable a track, the send bus assignments change from black-on-white to white-on-blue. What does this mean?
The effect I hear is that, while tracking, the signal of the record-enabled track is not being sent to the desired headphone mix.
Please see attached image of the track not record-enabled and also record-enabled.
Thanks!
Old 06-11-2014, 12:48 PM
Craig F Craig F is offline
Default Re: Send A-E bus assignments change colour
If you open the floating window for the Send what are the settings?
Also expand the Send lanes fro the track in the Edit Window, feels like some kind of Automation thing
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 06-11-2014, 12:50 PM
WOTE_Tech WOTE_Tech is offline
Hi SweetSoul,
When you have "Low Latency Monitoring" activated (Options>Low Latency Monitoring) All sends and inserts are bypassed when the corresponding track is record enabled.
The workaround that a lot of people do for this is to turn low latency monitoring off, then lower your H/W Buffer Size to a value that minimizes the latency to a manageable amount. (Setup>Playback Engine)
Old 06-11-2014, 12:53 PM
Thank you, WOTE_Tech! Super helpful and informative reply!
Mixer view: Send colour saturation to match Aux track destination?? BasketCase Pro Tools 11 11 01-07-2014 06:11 AM
Change colour pallet? holywoodj Windows 4 01-06-2013 04:11 AM
Tabbing between send assignments Peter Groom Post - Surround - Video 0 10-29-2010 06:57 AM
Is there a way to change marker colour? Phill Barrett Post - Surround - Video 4 10-16-2009 12:38 PM
