Old 11-01-2010, 11:13 AM
BummyDavis BummyDavis is offline
Default PT 8 LE: Microphone Issue
I have a iMac 27in and just hooked up my new mbox 2 mini. I have a MXL 990 microphone and it will not hook up. Hook up meaning I get no signal in the audio track. I have the 48v on and the Mic/ DI on as well. I'm sure there's questions you'll need to help me so please ask.
Old 11-01-2010, 11:43 AM
Stig Eliassen's Avatar
Default Re: PT 8 LE: Microphone Issue
Mic? DI? Which is it? You can't have both on the same input channel.
Old 11-01-2010, 11:49 AM
Andre Knecht Andre Knecht is offline
Welcome to the DUC, BummyDavis.
This is the PT TDM forum. Please note that there is a forum dedicated to ProTools LE and its various hardware options, such as your mbox 2 mini (scroll down from from the DUC’s main page and you’ll see it).
While most of the PT software is the same for both platforms, each has its own set of exclusive compatibility requirements, features, issues and problems. Therefore, most answers to such will vary also—highlighting the wisdom of posting on the appropriate forum.
As for your specific issue, while I don’t own a mbox 2 mini, I suspect that with the Mic/DI switch in the “on” position (as you describe) you actually defeat the microphone’s input path, activating the DI input instead.
PS: Be nice to your monitors/headphones/ears. Mute the unit’s output while making changes such as the ones discussed here.
IHTH — good luck!
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 11-01-2010, 01:01 PM
It's a pressable button on the back of the mbox. It just says Mic/ DI. Should I assume if the button is not pressed it means Mic and if it is it means DI?
Old 11-01-2010, 03:46 PM
The switch should be OUT for Mic(in for DI). You also need to use a straight XLR to XLR cable(the quarter inch inputs do not get phantom power).
Old 11-02-2010, 09:38 AM
Ya I have the XLR cable but the problem may be the XLR cable itself. The cable was sparking lightly. It's actually one I made a while ago... guess I didn't do it right. I'm gonna try another XLR. That may have been the problem.
Old 11-02-2010, 10:57 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Yes, sparks are not a good thing in audio. Make sure the XLR cable is straight through, that is pin 1 to 1, pin 2 to 2 etc.
You may have one of the active audio leads going to ground. That would cause a spark from the 48 volt phantom supply.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Microphone issue ... help? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-19-2010 07:29 AM
microphone francod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2007 06:14 PM
Mbox 2 + Microphone Issue globex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-30-2006 11:25 AM
mic pre VS microphone Help happasito Pro Tools TDM Systems (Mac) 1 03-01-2005 08:26 AM
mic pre VS microphone Help happasito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2005 03:23 AM
