Old 07-29-2011, 04:49 PM
julyen julyen is offline
Default FX Loop with loop station - how do I prevent the "cut" when changing rig?
With my Eleven Rack, I started to use the BOSS RC-50 Loop Station. To do that, I use the FX Loop send/return:
Eleven Rack send --> RC-50 instrument in (stereo)
RC-50 main out --> Eleven Rack Return (also stereo)
My main problem is that if the loop station is playing and I change to a different rig, there's a very audible "cut" or "blank" in the sound (I assume it's the FX Loop being disabled / enabled, it is on for all rigs I use for loops obviously). Any advice to prevent that would be appreciated.
Thanks!
Julien
Old 07-30-2011, 04:26 AM
CoiLive CoiLive is offline
Default Re: FX Loop with loop station - how do I prevent the "cut" when changing rig?
I believe the only way to do this right is:
1. Don't switch rigs
2. Switch rigs at the exact right time (depending on your loop the results may be better or worse :))
3. Place the loop station not in the FX loop, but after the output of the eleven rack. (11R --> Loop Station --> PA/Monitor/Whatever)
I'm also thinking about getting a loop station (or some other kind of looping device). So I'll be reading this :)
Old 08-01-2011, 01:57 PM
Thanks for your suggestions CoiLive!
I have a few other constraints unfortunately that makes it hard to implement them however.
I had originally started to write all the details but it got too confusing! In short:
- the eleven rack is used to record the performance (me + other musicians as described below) and as my personal PA through headphones (main out) so I can hear the other musicians;
- amp-out is used to send sound to the room / other musicians and is "locked" (don't change with the volume knob);
- line in would be available;
- digital: I have something coming in through spdif, can I use spdif out?
I'm not sure how I could get my sound "out" and back "in", so I can (1) hear myself along with the rest of the musicians I record and (2) record the looping...
Another strategy I thought of is to use the foot controller not to change rig, but to change the amp model, etc. and stay on the same "rig". I believe it can be done, need to dive in the MIDI documentation.
I'll post my results whatever they are when I try this (should be a matter of days at most depending on my schedule).
Thanks again for your input, it got me started again!
Julien
Old 08-14-2011, 01:00 AM
Following up as promised, here's what works for me in the context I'm using the loop station:
Eleven Rack "Output to Amp" (L+R) ---> Loop station in
Loop station out --> Eleven Rack line in (L+R)
The loop station has a few outs so I can use it to redirect the sound of my guitar to PA, etc. However, I lose the two line in entries, which will be a problem for me sometimes. I will try to be creative!
So, if anybody knows how to have an effect not switch off/on when changing rig, let us know.
Thanks again for your input!
Julien
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 07:09 AM
Wrong "auto-rating" of clips during loop recording joachim Pro Tools 11 5 02-11-2015 12:58 AM
Problem PT11 MAC stuck in "Playback Engine" selection reload loop fastermaster Pro Tools 11 3 06-28-2013 05:28 PM
Using Pro Tools live as a "Loop Station" Terrence3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-23-2010 12:45 PM
MIDI loop editing, "pattern style"? puckprotect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2009 11:50 AM
