Old 10-12-2023, 02:50 AM
huzzam huzzam is offline
Default BUG: changing Playback Engine freezes UI (23.9)
Hello,
I've been bitten twice now by this bug. If I change the Playback Engine, I'm able to select the new interface, but then the "OK" button is unresponsive. I can still move windows around the screen, but none of the UI elements respond. I tried hitting the "return" key and that also doesn't work.
Workaround is to force quit, then hold down N while starting up Pro Tools. That works correctly.
Macbook Air M1, system details in sig (except i'm running 2023.9, not 2023.6).
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 10-13-2023, 07:02 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: BUG: changing Playback Engine freezes UI (23.9)
Hi, what are you changing from/to?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Changing Playback Engine Rearranges Windows paul_g Pro Tools 2020 2 03-18-2021 04:51 AM
10.1.2/10.1.3 crashes when changing Playback Engine settings RokVox macOS 128 05-22-2012 01:51 PM
Changing the device Playback Engine uses RogerAF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2010 09:19 AM
PT crashes when changing Playback Engine Will Russell Pro Tools TDM Systems (Mac) 11 12-05-2006 08:15 AM
Changing Playback Engine in 7.0 Ozzie Pro Tools TDM Systems (Mac) 3 11-11-2005 11:11 AM
